Classic Audi » Technical » Technical Info » Wheel bolt length
Old 20-03-21, 01:49 PM   #1
BackintheFold
BackintheFold's Avatar
Default Wheel bolt length
Does anyone know the standard length for an ur wheel bolt please? Top to bottom-total length?
Thanks!!
I’ve been playing with my wheels. Those fitted had spacers (15mm) and long wheels bolts (70mm overall length) with tapered seating. I didn’t measure thread length. Will do tomorrow.
I think these may have been fitted with the other set of wheels the car had.
I now have the original Ronals Fitted with a full set of radius seating 27mm thread length bolts-which i believe are correct but any confirmation welcome!
I have put the others on the MB (where I sourced the right bolts. )
But they need to be changed, so I want to get the right size.
Thanks for any input.
2006 A3 (daily drive)
1987 MB ur
Old 20-03-21, 04:22 PM   #2
SorenR
SorenR's Avatar
Get your wheel, add the optional spacer, put in the bolt - if you got 1/2 to 1/1 the diameter of the bolt with thread free on the inside you are OK to go.
That rule has kept wheels on my cars for daily drive and trackdays ;-)
SorenR is offline   Reply With Quote
Old 20-03-21, 08:50 PM   #3
they're 27.5mm thread length
Old 20-03-21, 10:09 PM   #4
BackintheFold
Great. Thanks.
I will get some 45mm length M14 1.5 thread, 17mm spanner size, radius bolts ordered.
Those should fit the wheels/spacer combo.
1987 MB ur
