Classic Audi » Technical » Mech/Tech » Interior » UR door card removal
Old 12-09-19, 07:48 PM   #1
QuattroBird
Default UR door card removal
Hi. I did see once an article showing how to remove the door card inc handle etc. I need to see why the travel on my external door lever has increased making it difficult to open
Anyone have such info or direct me to the site
QuattroBird is offline   Reply With Quote
Old 12-09-19, 08:37 PM   #2
urquattr085
urquattr085's Avatar
I don't know the article, but it's pretty straightforward.
Remove all the screws from around the door pocket, plus one that is in the pocket divider (accessed by putting a pozi screwdriver through the carpeted section.
Remove the cover in the middle of the "mirror" triangle and the screw behind to reveal another screw holding a tab at the top of the door card.
Similarly, pop the cover behind the internal handle, remove screw & backplate, 2 screws in the underside of the door pull. If it's the driver's side, pop the connector for the mirror control.
Unscrew the locking knob on top.
Then it's 2/3 poppers down each side, lift it out of the window slot and Robert's your mothers brother
Regarding the handle travel, I also experienced this and found the handle casting to be cracked and required a replacement.
Hope this helps & good luck
1985 WR quattro
2010 A6 3.0Tdi Allroad
Old 12-09-19, 09:04 PM   #3
QuattroBird
Perfect thanks. Will get a new handle ready and get to work
Old 12-09-19, 09:20 PM   #4
urquattr085
Be careful of the plastic links between the handle and lock mechanisms, they can be a bit brittle.
1985 WR quattro
Old 13-09-19, 07:31 AM   #5
QuattroBird
Understood. Thanks for the heads up
Old 13-09-19, 08:14 AM   #6
BackintheFold
BackintheFold's Avatar
Those instructions are spot on-i only mention that to remove the inner grab handle you need to rotate it about 60 degrees clockwise to line up the slots with the retainers-you'll see what i mean when you do it...
also, anyone have a spare one of these "pop the cover behind the internal handle" and is at the meet on Sunday? I have £2 for you if you do!
Old 13-09-19, 03:20 PM   #7
urquattr085
I knew I'd miss something
Always happy to be corrected though
1985 WR quattro
Old 18-09-19, 11:27 AM   #8
QuattroBird
Finally got around to it last night. Door card all off, tip on handle useful. Handle to be replaced. Before I get forceful with the rods linked to the handle mechanism, do they pull out of the plastic cam and metal link?
Lever gave up the ghost as I went to open door to strip the card so new handle it is.
Old 18-09-19, 06:28 PM   #9
urquattr085
https://audi.7zap.com/en/rdw/audi+qu...6/8/837-78000/
Item 9 is a push fit into 29
Item 36 needs to be rotated to unclip it from item 8.
Item 8 can then be pulled out if the small lever on the handle
Remove screws 17 & 18 and you're there
Not much room for big hands like mine &you will lose some skin on those panel edges
Good luck with it
1985 WR quattro
Old 18-09-19, 07:47 PM   #10
QuattroBird
Perfect explanation thanks. Will crack on at the weekend ready for the new handle..... when it arrives.
