Classic Audi » Community » General Chat » Devastating loss
Old 10-06-19, 09:13 AM   #51
SwallownAmazon
SwallownAmazon's Avatar
It does question mark that insurance process though. If nothing else, because basic physics says metal is structurally different after thermal annealing.
While I have very sympathy for the owner, I couldn't agree more. As a retired industrial chemist with a bit of knowledge about the integrity of steel structures after fire, any car that has been in such a high temperature fire should not be put back on the road. You only have to look at what is done to make steel malleable and the subsequent plunging into cold water or oil to give it back its strength. Not practical with a car bodyshell.
Old 10-06-19, 09:43 AM   #52
You’ll probably know more about this than I, but isn’t it something like annealing occurs around 300deg and petrol burns around 900deg. So that suspension turret is toast. Literally.
Old 10-06-19, 03:35 PM   #53
SwallownAmazon
It's more like 500 deg C to heat to "cherry red" which is when steel softens but to get the strength back it needs to be tempered by plunging into cold water or sometimes, oil for specialist applications.
Old 10-06-19, 05:17 PM   #54
4v6
11K! Is there that amount of spares still left in it?
Ok engine box diffs some of the panels and wheels etc would be ok but that seems awfully steep.
As simmo says the steels been affected by the heat anyway, youd have to replace all those parts and where would you source them these days?
As stated rather unpalatable part of the process, shame to see a great car come to this.
Old 10-06-19, 05:50 PM   #55
Ben
Yeah, it's log book and ID.
1992 80 quattro 20vt
Old 10-06-19, 07:45 PM   #56
Originally Posted by theschmallfella View Post
I've always had one in all of my cars since an engine fire in a Fiat Ritmo (Strada) I had back in the early 90's where I was lucky to get away before it went up in a ball of smoke. I'd highly recommend having one in any classic car.
Are UK drivers legally not obliged to have one?
Originally Posted by moonwatcher View Post
Waste of time, I've had one in the car for twenty years
Never needed it
Better to have one and not need it, than other way around. We over here, in latvia, are required to have extinguisher in car to pass technical inspection, however control is lax, I haven't seen inspector to look at date label, all the control I've seen - the guy, when walking around the car, opens the boot and looks around in order to spot first aid kit and extinguisher. In any case, since I repair and upgrade my cars for me, not for technical inspection, I don't have obligatory 1 kg extinguisher - I have 4 kg extinguisher; I would prefer to have 8 kg, but it's inconveniently big.
Old 10-06-19, 07:57 PM   #57
When you look at the cost of a fire extinguisher and the cost of the loss of a lovely car like this, coupled with the emotional loss, hassle and inconvenience and the ultimate financial loss, a £16.00 AFFF 750g extinguisher is actually worth several thousand quid. Certainly more than a set of fancy wheels for those of such persuasion.... Hindsight is a wonderful thing sometimes...All, of course, in my humble opinion.
Old 11-06-19, 08:31 AM   #58
BackintheFold
BackintheFold's Avatar
Just throwing this in fro consideration, but as the car wasn't burnt out totally, it must have been hosed down by the fire brigade, yes?
Would that hosing down of hot metal be sufficient to temper the metal?
Old 11-06-19, 09:28 AM   #59
Fire brigade very likely used foam, not water.
Old 11-06-19, 09:36 AM   #60
BackintheFold
Can't see any foamy residue...
