Classic Audi » Technical » Mech/Tech » Suspension & Brakes » ABS sensors... ( I hope! )
Old 25-03-09, 09:51 AM   #1
Johnny_E
Johnny_E's Avatar
Default ABS sensors... ( I hope! )
Ok. The symptoms first....
Only occurs randomly, when coming to a slow and gentle stop. Just as the car almost draws to a halt, the ABS unit kicks in (bzzzzzzz).
Dirty sensors?
No ABS fault lights on show I must add and only happens when gently braking. I havent got a Haynes yet for the car (95 B4 coupe). I take it its an easy enough job to clean them? (brake cleaner/toothbrush job?)
John
Johnny_E is offline   Reply With Quote
Old 25-03-09, 10:55 AM   #2
BW2309
More than likely just as you say dirt, but actually in the castleated ring on the outter CV joint, it's this the sensor reads off. They become full of grime and rust and so the signal drops off when you get close to a halt. Give 'em a blow out with a can of brake and clutch cleaning spray. Also, worth checking it isn't caused by a split CV boot. If the boot splits it can fill the ring with grease.
Old 25-03-09, 11:05 AM   #3
Johnny_E
Johnny_E's Avatar
Good. Not the worst - unles sthe sensors are far gone I suppose. Even then, not a bog job though. Thanks!
abs sensors crisarc Parts For Sale 5 21-01-10 06:18 PM
Just shut your eyes and hope for the best. The Milkman General Chat 0 10-01-10 04:49 PM
sensors bart simpson Technical Info 1 23-10-09 08:45 PM
Hope Classic Car Show June 22nd Emjay Gatherings and Events 8 22-06-09 02:53 PM
