Classic Audi Ľ Technical Ľ Mech/Tech Ľ Electrical problems » 1994 Audi Coupe 2.0e ABS issues
Old 09-11-18, 10:40 AM   #1
m50yre
Smile 1994 Audi Coupe 2.0e ABS issues
Hi guys.
Wonder if you can help.
I have been fixing up an 80 Coupe for the past couple of years. Its now ready for MOT but i cannot get the ABS light out. Now all brakes have been removed, renewed, subframe off etc so everything is new. I cannot remember if the light was on when i got it, as it didnt run.
Ive had it on VCDS and the ABS controller cannot be communicated with.
Ive checked the ABS ECU and and got a spare to try that but makes no difference.
Only thing i can find is that the ABS ECU only gets a 6v feed - without a diagram im not sure if thats enough or if the only feed required?
Any thoughts?
m50yre is offline   Reply With Quote
Old 09-11-18, 11:07 AM   #2
Ben
Have you checked the fuse on the ABS relay? it's located under the dash behind the ign switch:
I've had a relay die, which is why I have a photo of one
Old 09-11-18, 11:16 AM   #3
m50yre
Hi, i saw this on another forum so went looking for that relay, but cannot find it, do all Coupes have them? Cheers
Old 09-11-18, 11:28 AM   #4
m50yre
Old 09-11-18, 11:55 AM   #5
Mellis46
Aero Advocate
Mellis46's Avatar
If its not where Ben said that ABS relay also can sometimes live under the back seat...
-1987 90 2.2E / Sapphire Blue (Rest in Pieces)
-1989 90 quattro with Sport Equipment / Satin Black
-1997 A4 Avant quattro TDI 110 / Tropical Green (Sold)
-2012 A1 Sport TFSI / Glacier White (Sold)
-2017 A1 Sportback S-line TFSI / Scuba Blue
Old 09-11-18, 01:22 PM   #6
Ben
Looking through some Audi B4 pdf's, it states (for LHD):
Removing and installing combi relay
Front left, beneath instrument panel in auxiliary relay plate
=> Current Flow Diagrams, Electrical Fault Finding; Fitting Locations
Note:
Switch off ignition for removal and installation. Not applicable as of model year 1993.
So you don't have one to check. It also says about the ABS ECU:
Prior to removal on vehicles as of model year 1993 interrogate fault memory with fault reader -V.A.G 1551-.
I put the pdf here if you want to have a read up: http://www.brita.plus.com/80q/FWD_Running_gear.pdf right click the link to download
Old 09-11-18, 01:31 PM   #7
For a 94 car, there is no relay. It's all contained in the ecu under the rear seat.
If you start the car up, the ABS light should go off within 5 seconds. If it doesn't it's likely a pump / modulator fault since you've already swapped the ecu.
There are 2 relays in the modulator which can be swapped out
1988 90 quattro project
Old 09-11-18, 02:22 PM   #8
m50yre
Thanks guys. Nah light stays on. Itís not turned a wheel for over ten years so I do wonder if once itís had a drive itíll sort itself out. Iíll keep you posted.
Cheers
Old 09-11-18, 03:03 PM   #9
Mellis46
Aero Advocate
Mellis46's Avatar
Good luck
Old 10-11-18, 01:03 PM   #10
m50yre
Thanks for the pdf. VCDS cannot read my ABS, is that normal? I had a 95 one years ago and Iím positive Vagcom could read abs on it?
