Classic Audi » Technical » Mech/Tech » Engine » Anyone fitted a WR Quattro air box in a KV?
Old 22-09-18, 12:25 PM   #1
Richi95
Default Anyone fitted a WR Quattro air box in a KV?
Hi there,
I’ve heard of people swapping in WR air boxes into a KV but the triangular opening vane won’t match up to existing air feed from the wing, as it’s a lot bigger. Just wanted to know if anyone fitted one and if they modified the chute and what they went for or just left it without the feed?
Thanks
Richi95 is offline   Reply With Quote
Old 22-09-18, 12:31 PM   #2
Originally Posted by Richi95 View Post
Hi there,
Thanks
My old KE engined GT had a Ur airbox. All of the plastic trunking in the wing goes in the bin. Ur quattro air intake is the triangular metal opening. It takes air from around the bottom of the headlight.
GT's with the plastic trunking had a habit of ingesting floodwater through it, so the Ur option is definately a wise one.
Old 22-09-18, 01:03 PM   #3
Richi95
Thanks for the reply issimo!
Ah brilliant! Did you notice much improvement in how it ran? I am going to give a go tomorrow, the air boxes are quite fiddly with the k jet on top!
Old 22-09-18, 01:12 PM   #4
Rather than noticing any power gain, I seem to recall the throttle response being quicker and the induction noise being louder. Neither a bad thing...
Old 22-09-18, 06:11 PM   #5
slammedAudi
I smoothed out some of the internals in the alloy box to improve the airflow, and reckon that I got a small gain.... However, it now has a tendency to ingest gravel if driving hard, every so often, I have to remove it from the back of the box, this is usually worst after driving on "tar and chip" repairs......
slammedAudi is offline   Reply With Quote
Old 22-09-18, 06:35 PM   #6
20vcqdriver
20vcqdriver's Avatar
Rather than all the trouble of fitting the Ur box Its just as effective to modify the bottom of the KV box and fit a K&N panel filter, All the gains without the pain Slacky now using my modified box on his and very happy with it as I'm sure he'll confirm
Old 22-09-18, 08:37 PM   #7
Richi95
20vcqdriver, how did you modify your box? Did you just drill it out? Did you modify any of the plastic feed pipe from the wing? I do have a K&N already in there, just trying to help it further breathe a bit better
Old 22-09-18, 09:31 PM   #8
slacky
slacky's Avatar
I confirm I’m very happy with it , slightly confused though , as you ‘modified’ the 90(KV) by drilling a few holes in & around the lower air box .., + the k & n .
The even more modified box I had off you is on the 80 sport , which sounds great & certainly makes it more responsive
90q-Cab.
2.3E-Ur-S6
-b2-80 Sport
Member 111
Old 22-09-18, 11:22 PM   #9
theschmallfella
theschmallfella's Avatar
Any photos of this kind of modification guys? What size holes and where?
Old 23-09-18, 02:53 PM   #10
Richi95
Originally Posted by theschmallfella View Post
any photos of this kind of modification guys? What size holes and where?
+1
