Classic Audi » Technical » Mech/Tech » Electrical problems » B3 80 Sport Centre Console switches - need help with wiring plugs!
Old 21-03-09, 09:30 PM   #1
Donald_MacIver
Default B3 80 Sport Centre Console switches - need help with wiring plugs!
Can someone please help me out. My car, a 89 G 80 sport only came with the rear screen heater and rear fog light switches, but i am going to fit a front bumper with front fogs, and have aquired the necessary extra switches. However, i am not sure if my car has the wiring in place or not. Can anyone tell me what the green and white wiring plugs in my car are for? The switch for the front fogs is white, so do i just plug it into the white wiring plug?
2006 Audi A4 3.0 TDi 233 BHP Avant Quattro S-line
1990 Audi 90 2.3 20v Sport
1990 Audi 80 2.0 16v Sport
1989 Audi 80 2.0 8v Sport
Donald_MacIver is offline   Reply With Quote
Old 21-03-09, 09:35 PM   #2
vag80
vag80's Avatar
Ithink all the switches are colour coded its years since i had mine out. have you got the multiplugs under
both headlamps for the fog lights. You will need the relay for the front fog lights
Old 21-03-09, 11:48 PM   #3
Donald_MacIver
I haven't checked behind the bumper yet
I have the relay and the harness if required in the pink 80 sport i have for spares, just wondered if my car already had the wiring in place or not judging by the extra wiring connectors in the dash. Does anyone know what the green connector would be for, and can someone clarify for me if the white connector may be for the front fogs?
Old 21-03-09, 11:53 PM   #4
kully
kully's Avatar
you dont need no relay or nothing, just connect your foglamps and fit the switch and it will all work , trust me its already prepared for fog lamp fitting with no messing about
Old 21-03-09, 11:56 PM   #5
Donald_MacIver
So does that go for my car too then, will the white plug be for front fogs? Don't want to blow anything up so want to be sure
Old 22-03-09, 12:02 AM   #6
kully
kully's Avatar
well thats what i done with mine, and it all works correctly, to check it all if you switch the rear fogs on the fronts will come on too
Centre console.... 4v6 Parts Wanted 11 01-10-09 08:22 PM
Sparkie Plugs Booty General Chat 17 12-08-09 03:16 PM
Spark Plugs for my 1989 80 2.0 8v 3A Sport? Donald_MacIver Engine 4 01-02-09 01:50 PM
1984 80 centre console Richie Parts Wanted 4 16-01-09 03:06 PM
spark plugs 100turbo c Engine 1 14-12-08 09:33 PM
