Classic Audi Ľ Community Ľ General Chat » Reality Check
Old 14-05-18, 09:02 PM   #51
Ben
Nice one
Old 14-05-18, 09:19 PM   #52
bigchewie
bigchewie's Avatar
Cracking work.
bigchewie is offline   Reply With Quote
Old 14-05-18, 09:42 PM   #53
urquattr085
urquattr085's Avatar
A great start. It'll be done by the weekend at that rate
1985 WR quattro
1983 80 Quattro - Sold many moons ago
Old 15-05-18, 12:03 PM   #54
Duffy3074
Working today so not as much progress!
It's had a replacement ignition lock at some point, hence 2 keys to operate the car, not good enough!
Both door locks and the boot lock stripped out and rebuilt to match the ignition.
This led me into the boot, the offside cluster was completely dead initially but much faffing about cleaning bulbs and the earth got everything working again.
Found that the offside rear shelf mount and one of the plastic clips for the cubby underneath that are both missing. Did search the boot but not there (I did find the screw for the mount however!)
Picked up the cab seats, the base foam on the passenger side is perfect so it's going on the drivers side of the Coupe. The map pocket elastic cords on these are the same as the Coupe, in other words knackered, so I've ordered some new elastic and will replace that when I refurb the seats.
Old 15-05-18, 02:03 PM   #55
mackenzie50
mackenzie50's Avatar
Impressed by your thoroughness and skills....I've also got a white B3 Coupe that would hugely benefit from your attention!!
mackenzie50 is offline   Reply With Quote
Old 15-05-18, 04:12 PM   #56
Duffy3074
We can discuss hourly rates!
Old 15-05-18, 06:29 PM   #57
sinbin5t
sinbin5t's Avatar
Is it difficult to do the lock barrels Duffy ? I'm a fumble fingers you see
Old 15-05-18, 07:14 PM   #58
Duffy3074
Once you access the lock itself it’s trial and error for the first lock and easy from there.
It’s one of these things that just makes sense for me and Mark on here pointed me towards doing it.
Old 15-05-18, 07:30 PM   #59
sinbin5t
sinbin5t's Avatar
Originally Posted by Duffy3074 View Post
Once you access the lock itself itís trial and error for the first lock and easy from there.
Itís one of these things that just makes sense for me and Mark on here pointed me towards doing it.
Could you possibly give me a quick description of what to do please Duffy, i know you're a busy man but i would like to get rid of the 2 key thing on mine.
Old 15-05-18, 07:52 PM   #60
Duffy3074
There are 7 plates that slide to a pre determined level dictated by the key, you need to swap the plates over (there are 4 possibilities for each slot) and you do them one at a time until they sit flush with the key in situ,
You note the number on each plate as you do them and that’s your new plate sequence for all of your locks.
