Classic Audi » Technical » Mech/Tech » Electrical problems » Battery light not going out.
Old 24-03-18, 12:47 PM   #21
If you don't need that bulb be illuminated, you can do like that If the ground pin will be connected to alternator, that bulb will work like alternator light should - it will be illuminated when alternator won't be working and it will go out after alternator will start to work.
Old 24-03-18, 02:24 PM   #22
I know you and I understand but not sure the OP does?
I described it as such so the bonnet wouldn't have to opened every time the engine was started.
John. is online now   Reply With Quote
Old 24-03-18, 05:28 PM   #23
...or engine revved...
If I would have such a problem, I wouldn't bother and would rev the engine, as connecting alternator to some bulb - that's too much effort for lazy arse like me...
Old 25-03-18, 08:11 AM   #24
krzracingcouk
krzracingcouk's Avatar
I am going to try that today, also read somewhere something about linking it to the oil press switch. Is this correct?
Not found the relay yet you mentioned, unless it is the one in the dash I have pulled that made no difference.
Audi = Acceleration Under Demonic Infulence
Current Car - Audi Coupe GT 5S 1982 Model Mark 1
Been in the family now for 30+ years.
Restoration Thread
Also Weekend Cars - Audi A4 Touring Car, Audi A4 DTM
krzracingcouk is offline   Reply With Quote
Old 25-03-18, 08:44 AM   #25
Originally Posted by krzracingcouk View Post
..... also read somewhere something about linking it to the oil press switch. Is this correct?
On a "normal" set up this would work, as yours has the flashing light/relay set up and there's a chance the problem is with dash(?) then maybe it wouldn't work? I don't know is my honest answer............MSH !
Old 25-03-18, 12:15 PM   #26
krzracingcouk
Latest update.....
A little confused but that is nothing new for me. Have been getting stressed with this issue and especially as I could not work out the relay I had to pull...... so.... looked at the fuse box and disconnect loads of bits, and reconnected just what I needed to get car running and replace afew connectors, and...... well started car battery light on still with flashing temperature light still. Touch the accelerator and the lights go out and VDO reads a happy 13.5v Carried on reconnecting things and making sure they are where they make sense being and well just done a 12 mile drive and car feels sweet.
Thank you guys for putting up with me
Restoration Thread
Old 25-03-18, 06:52 PM   #27
Sounds like a good result
