Classic Audi » Technical » Mech/Tech » Bodywork, glass & exterior fitments » Sunroof issue
Old 16-01-18, 02:12 AM   #1
Mar5den
Default Sunroof issue
Hiya all i need some advice of you guys the sunroof is broken on my Audi 80 b2 and I was wanting to know if there's anything I can do in regards to either buy parts for it or taking one from another car I've been told to just fill it in but then it means buying a new head lining any help at all would be very appreciated
Mar5den is offline   Reply With Quote
Old 16-01-18, 08:15 AM   #2
Duffy3074
What's the problem with it?
Is it OEM steel or aftermarket glass?
Old 16-01-18, 11:22 PM   #3
Mar5den
Thanks for the reply Duffy....its in bits and missing parts it was jammed half open the garage has managed to get it off but damaged it I dont was to fill it in because it means buying a new head lining what sunroofs will fit could I get a universal one
Old 17-01-18, 12:04 AM   #4
Jake Blight
Jake Blight's Avatar
Not sure if this would fit. Looks like it's from a coupe rather than an 80. Might be worth contacting them though.
https://rover.ebay.com/rover/0/0/0?m...2F322505089798
Jake Blight is offline   Reply With Quote
Old 17-01-18, 06:11 AM   #5
Duffy3074
I’ve got mine in bits at the moment , you could get a universal screen at whatever size was bigger than the original and cut the roof to fit but I think that’d be the last resort.
The sunroof (certainly on the B3) is not difficult to fit or remove. If you can find a car being broken it’d be worthwhile trying that route
Old 17-01-18, 10:50 AM   #6
Mar5den
All I've got that can be reused is the roof and sliders I'm missing everything else
Old 17-01-18, 10:52 AM   #7
Mar5den
So will a b3 sunroof fit
Old 17-01-18, 12:41 PM   #8
Hanuman
Hanuman's Avatar
It sounds like you need to take a look through the parts list to check for compatible bits, but my gut feeling is that you'd need a B2, and anything else is a distraction.
1986 80/90 sliding roof
https://audi.7zap.com/en/rdw/audi+80.../8/877-105000/
1986 80/90 sliding roof fitting parts
https://audi.7zap.com/en/rdw/audi+80.../8/877-106000/
1987 version
https://audi.7zap.com/en/rdw/audi+80.../8/877-105010/
Old 17-01-18, 01:12 PM   #9
Mar5den
Hiya thanks for the reply I've had a look and it going to cost a few £300+ for all the parts is it easy to replace the head lining if so does any one know where I can get one
Old 17-01-18, 01:16 PM   #10
Mar5den
Would the head lining out of coupe gt fit in 80
