Classic Audi » Classifieds section » Parts For Sale » Brian Rickets Tuned WN engine
Old 10-01-18, 03:17 PM   #1
simons2
Default Brian Rickets Tuned WN engine £250!!
Hello
1.9 5 pot 10V NA engine.
However its been modified by Brian Rickets renowned engine tuner of days gone by.
Great up-grade to a 1.9 or knackered 2.2 10V as this should be pumping out something like 140BHP+
Usual work includes head work, cam re-profile and fuel pressure increase.
In excellent condition with painted block black still looking like new.
£500 ono collected (Wiltshire) or could stick on a pallet £80.
PM if required.
Thanks
simons2 is offline   Reply With Quote
Old 12-01-18, 09:14 AM   #2
Colin Aitchison
Colin Aitchison's Avatar
Can you post a photo of the other side of the head including the inlet and exhaust ports please.
Old 12-01-18, 09:44 AM   #3
simons2
Hi Colin, no worries I'll sort this morning. Cheers Simon
Old 12-01-18, 11:30 AM   #4
simons2
There you go Colin. Regards Simon
Old 12-01-18, 12:10 PM   #5
Colin Aitchison
That answers my question, WN 1.9 is a carb engine, it looked like that was a fuel injection head in you first photos but the second set confirmed it, head looks ported and used, another daft question, do you know the size of the valves or are they just standard, The engine size 1.921 or 2.144 pistons are the same size, if you removed a spark plug and measured the stroke with a thin rod and turm the engine to confirm capacity 77.4mm = 1.921 and 86.6mm = 2.144, here I go again, re profiled cam and or any lift added, it will be a bucket and shim head.
Old 12-01-18, 12:42 PM   #6
simons2
Don't know valve size but was assured it was an 'up-rated head' valves, cam, porting.
I'll go out again and measure the stroke.
Do both capacities use the same size cam belt?
Old 12-01-18, 01:29 PM   #7
Colin Aitchison
Don't Know if they are the same size but the 2.144cc is 120 teeth x 18mm
Old 12-01-18, 02:08 PM   #8
simons2
OK belt is 120 teeth.
measured stroke best I could and got 89mm so must be 86.6
Code on head is 035 103 373G
The injection inserts look just like the KV ones on another head I have!!??
Also its got a warm up regulator on it, did carb engines have that!
Old 12-01-18, 05:33 PM   #9
No, carb engines have carb.
Old 12-01-18, 05:34 PM   #10
Sorry, I meant choke.
