Classic Audi » Classifieds section » Parts Wanted » UR GT dash switch bulbs
Old 04-01-18, 02:52 PM   #1
andya
andya's Avatar
Default UR GT dash switch bulbs
Bit of a random one - in the dash switches, there is a tiny bulb. I've got 3 dud ones. Anyone know where to get these replacement bulbs? I've tried the obvious places - gsf, eurocarparts, and other auto factors - most look at you with blank faces...
Thanks in advance.....
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 04-01-18, 03:19 PM   #2
hotsnot
I'm having a similar problem need bulbs for VDO gauges and heater control panel. I've think I've found the right ones but not sure - 286 bulbs?
hotsnot is offline   Reply With Quote
Old 04-01-18, 04:38 PM   #3
andya
andya's Avatar
I've got myself one of those 286 bulbs - it doesn't fit, its bigger than the original.
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 04-01-18, 05:13 PM   #4
simonthemedic
I have bought them from Maplins in the past, it's a small capless bulb, can't remember whether they plugged into the switch or I bent the small wires on the bulb and soldered them in. Later I replaced all the ones in my B2 with Led's and series resistors, fit and forget
simonthemedic is offline   Reply With Quote
Old 04-01-18, 05:59 PM   #5
andya
andya's Avatar
Yes your right, a replacement bulb would need to be soldered in. I guess Audi's idea was for you to simply replace the whole switch if that bulb went. We don't have that option nowadays!
I'll try maplins - cheers for that
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 04-01-18, 07:53 PM   #6
Ringmaster
Ringmaster's Avatar
Andya,
May I ask, what shade of silver do you have on your wheels, as pictured in your Avatar?
Old 04-01-18, 08:03 PM   #7
andya
andya's Avatar
that avatar pic is my old coupe I had a few years back. I did find out the paint code prior to getting them refurbed - I'll dig out the details.
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 04-01-18, 08:19 PM   #8
andya
andya's Avatar
I've remembered, and a quick google search to confirm - they were zermatt silver metallic LY7Y. I remember it well now, as the wheel refurbishers rang me up trying to find out the paint code after I had dropped them off. Minty on here brought them off me a couple of years back - if you want more pics, perhaps send him a line.
Cheers
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 05-01-18, 09:56 AM   #9
Ringmaster
Ringmaster's Avatar
Thank you Andya, that's been helpful...
Old 05-01-18, 10:21 PM   #10
20vcqdriver
20vcqdriver's Avatar
I've converted to led though also have a stock of original bulbs too
