Classic Audi » Technical » Mech/Tech » In-Car entertainment » Radio wiring diagram.
Old 04-01-18, 03:09 PM   #1
hotsnot
Default Radio wiring diagram.
So I've gone to swap the cassette player Apline headunit in my '87 coupe for a new one and the old one has been spliced into the cars wiring. I've ordered an ISO loom/socket but the diagram in the Haynes manual is sadly lacking as a useful wiring diagram. Does anyone have a better wiring diagram or failing that colour code pinouts? I will take a switched live fm the lighter cct as well, sick of having to remember to turn the radio off.
Cheers
Jase.
hotsnot is offline   Reply With Quote
Old 04-01-18, 03:57 PM   #2
The wiring is usually fairly standard for most Audis of that age
brown - earth
white - 12v
grey / blue - backlighting
blue / red - clock
your speaker wires will be in another group and they're usually black / green or black / white
Do not under any circumstances use a blue / white wire - that is for the vehicle speed and should never be used for the stereo.
Old 04-01-18, 07:11 PM   #3
Well, but what if he is going to use normal stereo with GALA function? That's why that particular wire is there, and it is in ISO plug as well.
Old 04-01-18, 07:17 PM   #4
does "87 coupe" means B2 coupe? If that would be B3, then "key in ignition" signal could be taken from ignition switch - no idea if B2 have such contact in ignition switch, althought I have some doubts...
Old 04-01-18, 07:55 PM   #5
hotsnot
It's a B2
Old 04-01-18, 07:57 PM   #6
hotsnot
brown - earth
white - 12v
blue / red - clock
My Alpine head unit does have speed control, so will the blue/white be ok to use?
Old 05-01-18, 01:22 PM   #7
That will be the back light wire which will dim the display.
The blue / white wire is for the vehicle electrics - it's completely independent of the radio circuit
