Members: 43,040 | Total Threads: 40,085 | Total Posts: 471,034 Currently Active Users: 1263 (0 members and 1263 guests) Welcome to our newest member, JeffreyDot |
I've got a '87 coupe gt with a tsr brands hatch engine with pack c head. It has started cutting out when it hits 4.5/5k rpm. This is after a tensioner change, it did find a knackered capped vacuum pipe near the throttle body. If it has sensed the timing is out and put the limiter on, how do you clear it, before I have to take it to a garage
?Jase |
Unless Im very much mistaken, which occurs fairly frequently, there ain't no codes.
Rotor arm? Basic timing?
What's a brands hatch engine and what's it based on ?
[quote=Hanuman;436107]Unless Im very much mistaken, which occurs fairly frequently, there ain't no codes.
I agree there are no codes on the B2, no idea what a brands hatch engine is but I know what a TSR stage 3 head is - bigger valves fully gas flowed I have the original TSR brochure somewhere, is it a 4 or 5 cylinder ? as in VW golf 1.8 or Audi 1.9/2.1 ? and is it injected or carb, some basic info needed to get you help with this. Will be either fuel or ignition or could be both, is the belt a tooth out ? Ony limiter I know on these is the spring loaded rotor arm, no electronics just mechanical old school stuff. Last edited by quattrodave; 07-11-17 at 07:33 PM. |
New rotor would be my first port of call, the rotor arm has a rev limiter built into it and the spring may have went week with age, a quick test would bet to super glue the rotor arm so the rev limiter is disabled.
It was a 1.8, now taken out to 2ltr
http://www.tsr-performance.com/websh...valve-package/ It's had a new rotor arm, will check the cap though it should be fine. |
If you don't want to super glue your new rotor arm fit one without the rev limiter, you can buy one, just a thought, you rev limiter may be getting triggered because you have reached your rev limit but you rev counter could be reading low.
#8 | |
Is the spring inside the rotor arm or is it part of the distributor? |
#9 | |
[quote=quattrodave;436125]
What timing marks were checked?
The mark on the crank V belt pulley is not reliable. Flywheel, cam gear and dizzy.
