Classic Audi » Technical » Mech/Tech » Electrical problems » Audi 100 urS4 / urS6 after run fan
Prev Previous Post   Next Post Next
Old 07-08-17, 09:28 AM   #4
Audimaan
Audimaan's Avatar
Smile
Originally Posted by Colin Aitchison View Post
Sorry in advance but never had a UrS6 but is the over run fan not controlled from the thermo/stat/switch in the bottom of the radiator, you will need to drain the coolant to change it but they are not expensive, one test would be, when the over run fan comes on after the engine is switch off, unplug the thermo/stat/switch, this is not a full proof test of the thremo/stat/switch because it may still be the relay, but the fan will be off and won't run down your battery, on the other hand if the fan stays on with the thermo/stat/switch unplugged you fault may be the relay stuck in the closed position, hope this helps.
Thanks its a good simple starting point, lets see......
Audimaan is offline   Reply With Quote
