Members: 43,040 | Total Threads: 40,085 | Total Posts: 471,034 Currently Active Users: 904 (2 members and 902 guests) Welcome to our newest member, JeffreyDot |
hi can anyone shed light on how to remove the door mirrors on the 80 b4 saloon cheers
You need to rotate them to reveal a pair of bolts in the base which secure them on the door.
Be careful with these. Only a 4mm allen bit and they're a soft material
cheers mate give it a try later,will this take everything off as i will be respraying the car.
#4 | |
Get loads of WD40 sprayed down there before you try and leave to soak for a while, as mentioned the bolt heads can be like chocolate, if you round them out it's a drilling out job then. After these are taken out the whole mirror is removed. |
yep 2 bolts stuck solid and rounding off, plenty of wd40 had been put on,and its the same bolt on either door so must be a problem with them,gonnae drill them out tonight after tea ,is there a wiring connection to be taken apart after all this and is it in the door skin or mirror cheers.
#6 | |
Take your time and you will be okay ![]() |
thanks for that mate well appreciated cheers
yep 2 bolts jammed solid ,drilled out 1 was a right bugger had to drill halfway down the mirror shaft to release it, cleaned out the door bottom now sitting down with a can of magners, well you have to on a friday night if not going out cheers guys.
