Classic Audi » Classifieds section » Cars For Sale » 100 S4 Quattro
Old 15-03-17, 09:44 AM   #31
vorsprung durch technik
Just read that your capable of doing suspension rebuilds.Right then.......your capable of doing this also to fix your misfire problems. Your wiring for the coils is most likely cracked and arcing all over the place. Take the lid of and show us a close up pic,only 3 x allen bolts. If it's cracked, you need a new loom. So you might as well approach Alex on here (error404) and S2 forum for one of his new looms and then buy the modern coils he recommends.All this is very easy to do and needs no specialist knowledge. This should be your first port of call. I'm assuming your car is producing good pressure on all cylinders.What's the mileage?
Ps,you mention misfiring.I take it it's running on all 5 cylinders?? The other fairly common fault is it runs on 4 because the POS (power output stages) is playing up. This is also a very easily replaced part. Plus gaps are also vital to ensuring a clean burn and if they're too big this can also produce misfires. I could check for you later the plug gaps but have to dash. HTH.
Old 15-03-17, 12:44 PM   #32
Audimaan
Audimaan's Avatar
Thumbs up
Hi, thanks for the info, I'm now inclined to look into the POS you mentioned. Pressure was good on all cyl. with 103k miles. We have checked it for sparks from the new plugs which all work fine of all 4 cyl. So even by swaping the new coil and new spark plugs between cyl number 4 & 5 we got the same result. So coil and spark plug works fine from 4th but never in 5th cyl. I shall investigate further on this POS when time allows.
Any more info on POS and its availability would be appreciated if anyone does know please. Thanks pal.
Audimaan is offline   Reply With Quote
Old 15-03-17, 02:52 PM   #33
I'll dig out the Professors info later.
Old 15-03-17, 03:02 PM   #34
sinbin5t
sinbin5t's Avatar
And post some photo's of the new bench too
Old 15-03-17, 03:02 PM   #35
Yes mate.
Old 15-03-17, 03:06 PM   #36
sinbin5t
sinbin5t's Avatar
Yes mate.
Old 16-03-17, 01:04 AM   #37
Audimaan
Audimaan's Avatar
Thumbs up
am looking out for Alex here, put a message hopefully to the right person.
Thanks.
Old 24-04-17, 05:43 PM   #38
Audimaan
Audimaan's Avatar
Default Car Sale withdrawn.
Until any further notice, this car will Not be available for sale, sorry for any inconvenience, Thanks.
Old 25-04-17, 11:08 AM   #39
Hanuman
Hanuman's Avatar
🤔 When was this !! 😂
Around about the time that the fuel tank was replaced, give or take a few months.
Memory issues- I put it down to navy grog, and bending down to quickly!
Tags
audi 100 s4, auto, for sale
