Classic Audi » Technical » Mech/Tech » Engine » Water flange with temp sender on.
Old 10-04-17, 04:28 PM   #1
Crossle
Crossle's Avatar
Default Water flange with temp sender on.
I traced an faulty Water Gauge to a plug in the egine bay a while ago and must admit not bothered to do anything about it yet. This is a 2.3 20V 7A engine. There is a water pipe which connects to a flange off the side of the block, on this flange is an electrical plug which seem to be the sender for the Water Gauge. This plug is faulty as the gauge works for a bit if a wiggle it around a bit/pull it out and push it back in.
Anyone know the part number for this part?
Crossle is offline   Reply With Quote
Old 10-04-17, 07:08 PM   #2
What do you need the part number for ?
The sensor, the connector or the flange ?
It's a common fault and its often the rubber boot fills up with water due to the sensor cracking (often overtightened or just old age).
The brown connector is NLA I believe
Old 10-04-17, 09:55 PM   #3
Crossle
Crossle's Avatar
I assumed the sensor would need to be changed with the flange? The rubber boot has always been dry when I've checked but it's well perished and not doing alot
Old 11-04-17, 08:58 AM   #4
Duffy3074
Its separate
Look it up here
https://7zap.com/en/
Old 11-04-17, 10:09 AM   #5
vorsprung durch technik
Originally Posted by Duffy3074 View Post
Its separate
Look it up here
I tried yesterday but couldn't identify the part,would be interested to know which part Crossle is referring too?
Old 11-04-17, 11:28 AM   #6
Duffy3074
http://audi.7zap.com/en/rdw/audi+cou.../9/919-919065/
comes under electrics and I presume it's part 5
Old 11-04-17, 11:56 AM   #7
That's the slide i looked at but wasn't sure.I was thinking N05 is the o ring and it's either item 9 or 10 but it says for KV.
Old 11-04-17, 11:59 AM   #8
Tun
Tun's Avatar
Multi function temp switch, like this one I think.
http://www.ebay.co.uk/itm/Temperatur...oAAOSw3ydVoZjW
1988 MB quattro
2012 S4 Avant
Old 11-04-17, 02:00 PM   #9
Crossle
Crossle's Avatar
Great info as always thanks- looks like the right part to me. Its such a small flange that i was thinking it would all be one part- think its going to easier to take the whole flange off to change it.
Old 11-04-17, 02:10 PM   #10
Tun
Tun's Avatar
Much easier job than it looks. If I remember rightly I disconnected the braided fuel lines, watch out for the release of pressure, to get better access but other than that it was straight forward job.
1988 MB quattro
2012 S4 Avant
