Members: 19,772 | Total Threads: 40,089 | Total Posts: 471,076 Currently Active Users: 1738 (1 members and 1737 guests) Welcome to our newest member, Esmeraldosvhc |
#11 |
first of all, I'd give it chance to settle.
As you've only just put them on. |
#12 |
Just a thought, an old trick I remember from some of the guys in the SCCA. Auto -Crossers in early VW Golfs and Hondas put the springs in the oven at 500 degrees F. for some hours, which as I understand it relaxed the spring by SMALL intervals. I believe this gave them very specific ride heights with a variety of wheel combinations.
I have not done this, and am no expert. Just putting it out there for discussion. |
#13 | |
#14 |
Yeh, sounds right. I'm checking with some old Auto-X buddies now.
Stay tuned. |
#15 |
Theres another aspect to this besides the spring rate change that cutting the spring will achieve, and thats the fact that springs and dampers are a matched pair.
Suspension engineers go to great lengths to ensure that a dmaper is matched to the spring it has to control. Its a bit like pushing someone on a swing where if you time it right theyll go higher and higher as each push adds momentum, wheras if you time it wrong theyll stall and slow down -which is what a damper does to a spring. Anytime the rate of the spring is altered, youll need to alter the damping rates to best match the new rate. If you dont youll get a spring thats not being controlled correctly leading to pitching, poor control of the tyre over undulations and bumps, you can end up with a car thats got lengthened stopping distances also. Best to go the whole hog and get a kit where the dampers and springs are matched. |
#16 |
its not big and its not clever. dont do it
#17 |
Yeah, just like he said......nuff said!!
#18 |
big gimping
right ok, the reason i say chop a coil off is simply i can not find a set 80mm springs anywhere, they make them for the golf and jetta but thats all i can find, i aint doing it for better handling, remember its an old diesel not a quattro. il ride on the 60mm another month, i think maybe 15's might make it look lower by filling the arch better. will post pics soon.
#19 |
put a couple of bags of sand in the boot!
and a full tank of juice will help as well! |
#20 |
coilovers???
air bags? Get some piccies up of it now, and we'll have a vote to let you know if you need to go lower. |
| UR Springs | stumack7 | Suspension & Brakes | 1 | 14-05-09 04:19 PM |
| G Max Springs | poopcoupe | General Chat | 9 | 23-04-09 10:35 PM |
| CQ rear springs | Daveymaclad | Parts Wanted | 0 | 15-03-09 04:32 PM |
| Uprated springs | quattropower | Parts Wanted | 0 | 23-01-09 09:37 PM |
| Lowered Springs. | Coxy | Suspension & Brakes | 38 | 29-11-07 02:18 PM |
