Members: 43,038 | Total Threads: 40,083 | Total Posts: 471,018 Currently Active Users: 613 (1 members and 612 guests) Welcome to our newest member, KrabWaw |
#11 |
#12 |
Cheers for all thoughts gents, serious & otherwise - will report back
1984 GT5E Topaz Green 1982 GT5S Helios Blue - now in Ireland 1983 GT5E Topaz Green - donor 1986 GT 2.0 Tornado Red - long gone 2001 A6 2.4 V6 - exported to Ireland |
#13 |
All
FYI horn repaired - thx for all suggestions - problem was a poor connection at one of the horn terminals. Checks made in following order: (i) fuse - the fuse is shared with the brake lights which work, so fuse discounted (ii) connection on steering wheel - prized the horn push from the centre, removed spade connector & pressed against exposed end of steering column. This produced an audible relay click, suggesting a working circuit (iii) pulled wires (spade connectors) from all four terminals on the horn (there are two horns each with two terminals), cleaned terminals, slid spade terminals back on & horn sounds again Took all of 15 mins but I broke one of the horn push retainers on the steering wheel ![]() If anyone has any B2 facelift horn push retainers, or a grotty B2 facelift steering wheel which could be for sale, pls PM me
#14 | |
![]() I got a few off eBay as replacements and it was just the retainers I purchased, I'll have a look and see if I can find the partnumber or seller I used. |
#15 |
If you don't have any luck in this country
http://p-arts.ch/index.php?a=485&lang=eng Hope this helps, I've used them before and the service was good.
#16 |
Thx Both
#17 |
The part you want is the following number;
321419779A There are a couple on eBay at the moment... https://www.ebay.co.uk/itm/132117468129 https://www.ebay.co.uk/itm/301204522148 I would try the main dealers though, they should be cheaper, it's a shared part with VW and they are usually cheaper than Audi, same part number. |
#18 |
Thx Sie, you're a star
I will try VW first as you suggest
#19 |
did you get this sorted? I've got a centre piece of an old steering wheel, not sure what bits are on it, Its yours if you need it
#20 |
Thx Dave, I'll PM you
