Classic Audi » Technical » Mech/Tech » Electrical problems » Electric Window Motor Help please
Old 08-02-17, 04:12 PM   #11
Crossle
Crossle's Avatar
Great info thanks guys. At this point I have to embarrassingly say I am not a mechanic- take a wheel off is about as far as I go. I have never taken a door card off before and wouldnt know where to start? Pain to have to do it as well as my door card is already all torn to bits
Crossle is offline   Reply With Quote
Old 08-02-17, 04:39 PM   #12
DETROITPISTON
Park on a solid piece of ground where you can open the door and walk around comfortably.
From memory:-
You'll need a posi screwdriver to remove the small screw in the side of the doorcard near the lock.
Also, posi driver to remove the screw behind the door card handle trigger.
Then a long series allen key or socket to get into the two very small holes on the underside and side of the doorcard grab handle to remove it. They're right underneath and in order to locate the allen key you might have to lay upside down and shine a bright torch into the small holes to align it. Occasionally these have been replaced so if you're having trouble just make sure they haven't been swapped with screws etc.
When revealed remove the little l shaped bracket with the posi driver.
Unhook the door trigger cable and put the little clip that holds it in place into a safe place.
The doorcard can then be pushed/pulled vertically upwards and out of the way.
Refitting is the reverse but make sure when you lower the doorcard vertically downwards into place the lock/unlock rod goes through the little hole at the top of the doorcard.
Don't think ive forgotten anything but you'd soon work it out anyway.
DETROITPISTON is offline   Reply With Quote
Old 08-02-17, 04:41 PM   #13
Audiden
Audiden's Avatar
It's the cables and/or plastic guides that normally snap on the window regulators as opposed to the motor failing, particularly on Coupes/Cabs
Too many cars!!
Old 08-02-17, 06:10 PM   #14
sinbin5t
sinbin5t's Avatar
Originally Posted by the red baron View Post
Have you been to the Jeremy Clarckson school of motor mechanics vorsprung?
He taught Jeremy everything he knows
Old 08-02-17, 06:47 PM   #15
DGSdale
From memory:-
That's pretty much it but I have to be a bit anal here (I'll not apologise for it but I am naturally anal!) This is a real bugbear of mine. The correct screwdriver to use is a Phillips (no.2 in this case) not a Pozi-Drive. I don't think Audi have ever used Pozi-Drive screws. If anybody is interested the details are here:
https://bsfixings.uk/the-difference-...and-pozi-screw
2012 B8.5 [color="Red"]A4 2.0TFSI quattro Avant Black Edition - Lava Grey [color="Red"] - Current
2008 B7 S4 4.2 V8 Cabriolet - Moro Blue - Current
2005 B6 A4 3.0 Sport Cabriolet - Moro Blue - sold
2000 B4 80 2.6 Cabriolet Final Edition - Ming Blue - sold - & missed
2003 C5 A6 3.0 quattro Avant - Night Blue - current
1998 C5 A6 2.8 quattro Avant - Ming Blue - sold
1994 B4 80 2.6SE Avant - Indigo Pearl - sold - & missed
1993 B4 80 2.0 16V Sport - Gomera Green - sold
DGSdale is offline   Reply With Quote
