Members: 19,810 | Total Threads: 40,093 | Total Posts: 471,108 Currently Active Users: 12014 (3 members and 12011 guests) Welcome to our newest member, minihjopia |
Please can anyone help. The driver's door on my UR quattro does not open easily from the outside. Sometimes not at all. The central locking works ok and it opens easily from the inside. Any help would be appreciated, thanks.
Sounds like you need a new outer handle....or maybe just some serious lubrication?
Thanks Frank. It feels as though the latch on the handle has nearly come away. I'll try some lubrication first. And then perhaps get a new handle. Unless anyone else has had the exact same problem an found a different fix.
Had the same problem on my 5T, same type of handle, part of the lever mechanism had snapped on one side, only visible if you remove the handle.
#6 | |
I know that problem. Eventually that handle will snap. Those handles are readily available. I brought one from gsf, but it lasted only 6 months, the build quality was awful. I ended up buying one from Pete Reeve from Quattro Corner, I think it was about 20 quid.
Also buy this : http://www.ebay.co.uk/itm/262216466381 If you break the original clip your stuck!! Believe me, from experience.......
pistol trigger VAG door handles are a pain in the ass when they don't work, and its even more of a pain in the ass if you have a more door!
I bought those cheap ebay ones in the past and they are horrible to fit and use, in the end I just used them for spare parts and managed to get the original ones working again with some hoekery poekery. |
#9 | |
Another note on the lookalike replacement handles.
From memory, the lock components are not always directly interchangeable between the original Audi parts and the aftermarket bits, so some fettling may be needed. Stick with OEM if you can.
