Classic Audi » Classifieds section » Parts Wanted » Alternator for a 7A
Old 27-10-16, 09:13 AM   #1
Crossle
Crossle's Avatar
Default Alternator for a 7A
2.3 20v engine Coupe (7A) I need an alternator if anyone has one please.
Crossle is offline   Reply With Quote
Old 27-10-16, 12:24 PM   #2
Audiden
Audiden's Avatar
If your alternator has simply stopped charging, it'll probably be the regulator on the back that needs changed...
Too many cars!!
Old 27-10-16, 03:56 PM   #3
Read somewhere that you can replace it with a 15v type as opposed to 14??
Can anyone confirm?
Old 27-10-16, 04:57 PM   #4
Crossle
Crossle's Avatar
Its working but the pulley is on its way out judging by the sound!
Old 27-10-16, 06:55 PM   #5
Andy10v
Andy10v's Avatar
Can anyone confirm?
You can fit a diode to take it up a bit.
http://www.hax.se/alternator/
2005 350z GT
Sold-1993 ABY coupe
Old 27-10-16, 07:13 PM   #6
I see, I thought it was a different unit as opposed to a modification.
Have you done this before Andy?
Old 27-10-16, 07:32 PM   #7
Andy10v
Andy10v's Avatar
15v regulator for a 7A/3B below, dont know of one for ABY. At £12 not really worth fitting a diode then!
I have never done fitted a 15v reg, relaying the headlights and fuel pump make a big difference if you measure the voltage drop.
http://www.s2forum.com/forum/showthr...t=19577&page=2
Originally Posted by s2driveruk View Post
As bosch handily supplied an incorrect part number, (suggested 1197311548) and subsequently the part I thought i'd hunt for the right one and if possible the 15v version of the voltage regulator too. Quick search revealed the following:
http://www.woodauto.com/Component.aspx?Ref=VRG46410 15v upgrade replacement
http://www.woodauto.com/Component.aspx?Ref=VRG4641 14v straight replacement
3b with a/c
http://www.woodauto.com/Component.as...=EXA2111271152
3b no a/c
http://www.woodauto.com/Component.aspx?Ref=EXA211127902
ABY
http://www.woodauto.com/Component.as...=EXA5111021102
RS2 with a/c
http://www.woodauto.com/Component.as...=EXA2111761202
RS2 no a/c
http://www.woodauto.com/Component.aspx?Ref=EXA211163902
2005 350z GT
Sold-1993 ABY coupe
Old 27-10-16, 10:06 PM   #8
corrpeden
I think I have one here if you have pic or part number as I have several
corrpeden is offline   Reply With Quote
Old 31-10-16, 12:53 PM   #9
Crossle
Crossle's Avatar
Sorry- false alarm! I was convinced my Alternator had gone because it was noisy and the belt looked fine to me. However I changed the belt at the weekend and it seems fine now.
