Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Incorrect strut insert?
Old 06-07-16, 02:00 PM   #11
Tun
Tun's Avatar
The diameter of the shaft was greater on the replacement unit, which is why they supply them with new caps and why you cant re-use the originals.
1988 MB quattro
2012 S4 Avant
Old 06-07-16, 02:15 PM   #12
It's the shape of the insert - the cap is designed to fit around it to clamp it in place.
You also don't use bump stops if you go with Bilstein as they have internal ones
Old 06-07-16, 04:12 PM   #13
Mellis46
Aero Advocate
Mellis46's Avatar
Do the top caps come with the inserts then or are they something u have to source separately?
Old 06-07-16, 10:40 PM   #14
typically aftermarket shocks will come with the caps.
From the dealer, you need to buy caps as individual items
Old 10-07-16, 10:18 PM   #15
Duffy3074
Originally Posted by Tun View Post
I bought a replacement insert for mine from demon tweeks but it was too long, and the cap was different so the gaiter didn't fit so I sent it back. I have had these in my watch list for a long time.
http://www.ebay.co.uk/itm/3813315247...%3AMEBIDX%3AIT
I dread to think of how much time I have spent trying to get rid of noises from my 90's front suspension, more top mounts than I can count, bottom ball joints, drop links wishbone bushes and steering rack steering rack damper....and the noise is still there
I've spent a while chasing knocks on my 90 front suspension, turned out that the front springs on a B3 are ended but it's not obvious (there's about 8mm in it) get them the wrong way round and they are noisy.
Old 11-07-16, 09:16 AM   #16
Paint marks should be at the bottom of the spring if they are OE
