Members: 43,049 | Total Threads: 40,086 | Total Posts: 471,040 Currently Active Users: 2326 (2 members and 2324 guests) Welcome to our newest member, Josephnep |
Just a small problem, my Cq starts first time when hot OR cold will not fire up if warm, drive half a mile and stop and then it's a no go, leave it 1-2 hours and she's raring to go, any ideas or suggestions
Coupe Quattro 1985
Have you looked at the fuel pump relay? I had a similar problem on my cq. Gsf sell them at 26 ish quid.
Regards
I'll have a look later
Coupe Quattro 1985
Hey moonwatcher
Not sure of the set up on the CQ, but I had the same problem with my 80 a while back ![]() My ignition barrel had been sticky for a while, and well, I'd drive somewhere and would then have to wait until the engine had cooled down (or use jump leads) before my boy would start again; was a nightmare in the summer months when temperatures were souring I can tell you! Well, after many months of trying to diagnose the problem to no avail, I then read something about cracked ignition switches causing restart issues, this being due to heat expansion preventing the switch from engaging properly when the engine is warm/hot. Ordered a replacement ignition barrel & switch, had it fitted, and well, a year or so later and the problem would seem to have been resolved. ![]() This is my old switch: Not only cracked but starting to fry too - good job that I found that article when I did! ![]() Last edited by leggy; 29-03-16 at 12:30 PM. |
I first happened about ten years ago, I drove about half a mile, incoming mobile call, pulled into a lay bye, turned the engine off ( nice and legal ) and afterwards wouldn't start. It went perfect to AITP last year and last week drove about same distance, stopped for about 15 minutes and it happened again. Yesterday took her for a 10 mile run, stopped and started again perfect. As long as she is up to temperature or stone cold she works perfectly
Coupe Quattro 1985
Mine didn't have the problem regularly to begin with moonwatcher...
was intermittent for quite some years before it became a real headache for me; being more noticeable like I say on warm/hot days. Wish I'd have checked my switch sooner to be fair, would have saved me a whole heap of hassle, not to mention garage diagnostic bills and the embarrassment of having to flag down strangers every time I needed a jump start. ![]() |
