Members: 43,028 | Total Threads: 40,083 | Total Posts: 471,017 Currently Active Users: 1099 (0 members and 1099 guests) Welcome to our newest member, Esmeraldossyc |
Hi All,
I am curing a leak around the rear lights and there is no rubber gasket between the light housing and the body,just a load of sealant. Should there be a gasket and where could I find one? If not, what sealant is best? I have some window frame silicone sealant but it seems a bit rubbery and flimsy so might not be up to it. Thanks folks. |
I normally use dum dum which comes in a can and can be rolled similar to plasticine and then used to form a worm of sealant in the ridge on the light fitting. Just done a quick search and it appears its no longer in manufacture. someone must make an alternative, whatever you do don't use anything that is a permenant bond as you'll never get the light off again at a later date (tigerseal or silkoflex is a no no).
Good thing about dum dum is that you can remove and reuse it. this should work as its similar but much more expensive ! http://www.ebay.co.uk/itm/Eastwood-F...AAAOSwNSxVXFy8 or this http://www.ebay.co.uk/itm/DUM-DUM-DU...25.m3641.l6368 Last edited by quattrodave; 23-01-16 at 03:44 PM. |
#3 | |
Coupe Quattro 1985
I used something called butyl tape which you can get from VW as per the oem stuff.
Bit expensive mind you as they only usually sell it in 6 or so rolls. |
The OEM stuff is sealant on a roll as Tony says.
You can get individual rolls of butyl tape on ebay, just make sure you get square/round stuff, not the wide flat tape.
Cheers for the advice guys- I have ordered some butyl tape.
ta |
