Members: 43,031 | Total Threads: 40,083 | Total Posts: 471,017 Currently Active Users: 3684 (1 members and 3683 guests) Welcome to our newest member, Clamcasexgd |
KV in a b3 90 quattro
Bought as a project. Had poor idle. Changed ISV rubber pipe for a hole free one. Idles fine now. New dizzy cap and rotor arm New plugs Small vac pipes replaced. Starts and revs fine for about a minute Then gradually starts to spit its dummy and starts missing when revved Won't then Rev over 4k, then gradually gets worse and won't Rev at all and cuts out. Any ideas folks? Been a long time since I've messed with a KV so running out of ideas. |
Have you read this thread? It may be of use. Good luck sorting it out.
http://www.classic-audi.co.uk/forum/...ad.php?t=24516 |
some pointers here Dave
http://www.classic-audi.co.uk/forum/...t=24419&page=2
Thanks for the links guys
I did think fuel related as ok at idle Will do the tank WUR and metering head filters Any where available where I can buy new filter for WUR ? |
Bump
Any ideas? Also been told about ignition module On type 85 anyway was under driver side dash on Ali plate Is there one on b3? Behind kick panel maybe Need to get this running right for the MOT |
#6 | |
Starts fine
Issues develop once been run for a few minutes Gradually refusing to rev until cuts But restarts and idles fine Really want it MOT d for autumn Sunday morning blasts before it has to be sold on |
fuel pump/filter?
It's your K-Jet, most likely the 'piston' that moves up and down and is operated by the round flap.
Remove the metering head from the top of the airbox, turn it upside down, then you see 2 bend pieces of metal, open them up and take the piston out, don't loose the spring that's behind it! Clean it up and polish it and put it back in. However now I come to think of it, try to adjust the CO first though the small pipe on the metering head. This helped on my 90q the last time I had this issue. The screw can be turned with a small hex key? Anyway, start the car and keep it running by operating the throttle, give the CO screw a half turn or less left or right and see if it helps. |
Check if yours has an o2 sensor?
Do the exhaust fumes smell very rich when it starts to die off? I had a problem with my car at the start of the year, same sort of symtoms, turned out to be a faulty o2 sensor, for whatever reason it was telling the car it was running lean and richened the mixture until it wouldn't run. just a thought. |
