Members: 19,795 | Total Threads: 40,092 | Total Posts: 471,099 Currently Active Users: 2126 (2 members and 2124 guests) Welcome to our newest member, WatWat |
#11 | |
Apparently the difference between both might be power rating. |
#12 |
Interesting. I pulled those numbers from Vagcat!
#13 |
I found the info you mentioned above...
http://www.isham-research.co.uk/quattro/tech.html#elec Am I right in saying that the sub-pages relevant to my car's engine are as follows? MB ECU codes, diagnostics and pinouts MB ECU self-diagnosis Last edited by John Clayton; 08-10-15 at 09:06 PM. |
#14 |
I think I took similar(same) relay from an ng engined coupe last week
Will see if I can find it |
#15 |
If you have a 1B engine then yes, the MB instructions are correct for your car
#16 |
Being a 1987 vehicle, wouldn't it be KG engined, still?
#17 |
The kg engine doesn't use that relay though.
It's a different method for reading codes http://www.isham-research.co.uk/quattro/codes_kg.html
#18 |
How can I tell whether my engine is KG or 1B? Based upon the fact that it needs the specified relay for its fault codes, am I right in saying that it must therefore be a 1B engine?
#19 |
Will be on your V5 or also on the side of the block.
it could be the garage are talking out their arse
#20 |
According to the V5 the engine no. is: KG022506
