Members: 19,774 | Total Threads: 40,089 | Total Posts: 471,077 Currently Active Users: 1712 (2 members and 1710 guests) Welcome to our newest member, stabgenmt |
The garage reported to me:
"We cannot initiate the diagnostic program because the fuel pump relay has been changed for an aftermarket one. It is meant to have a socket on the top of it in which a fuse is temporarily fitted to initiate the diagnostics. The relay fitted is an off the shelf one." The car is an '87 Audi 200 AVANT Quattro Turbo [2.2 petrol injection, manual gearbox] Does anyone have the original relay for sale, please? |
Sounds like you need relay 215
Still readily available
Thanks. Do you mean that you can still buy them new?
Any suggestions where I can get one? |
Audi?
Flippant, I know, but you'd be surprised how much you can still get, and at reasonable cost compared to Internet auctions. (24) 8A0951253 contact close relay / for fuel pump / relay location: / F >> 44-F-300 000* 10 / KG,JY (24) 191906383C contact close relay / for fuel pump / relay location: / F 44-G-000 001>>* 10 / KG,JY It might be one of those, but I won't be able to check for a few days. I do have a couple somewhere which need fixing.
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 08-10-15 at 04:07 PM. |
Tell them to straighten out their curved hands, or change garage to one where works smarter folk. L line, which they want to ground by plugging in fuse, is also connected to diagnostic connectors, found somewhere in drivers footwell, I presume, so all is needed in this case, is just small piece of wire to connect two pins. Actually I'm wondering what they want to achieve - did UK C3's came with check engine light installed?
In case if you still want to change relay - not only 215, but also 213 could be used. 215 is higher rated version of 213, I guess it was used for engines where it had to handle not only fuel pump, but also injectors - 20v/20vt engines. |
There are a few unique aspects to the right hand drive set-ups compared with their original left hand drive counterparts. So, such simple items as fitting a bulb in the check engine light position doesn't actually work in some cases as possibly no such thing exists on RHD, while left hand drive has it. (Thinking V8 diagnostics, for an example)
But the check light still requires a trigger, doesn't it? Which is the two contacts in te lid of the relay. Btw. If someone identifies the correct relay, I'll edit my previous post accordingly.
Great advice -thanks Gents!
I think I need to order this one, unless anyone advises otherwise... Audi No 215 Contact Close Relay - Part Number 443951253l http://www.ebay.co.uk/itm/Audi-No-21...-/281420378037 |
#8 | |
Reading a discussion on the subject for the V8 on a U.S. Site, it transpired that on North American market cars, (whether all, or just certain m.y chassis, I don't know), the check engine light bulb was omitted, but otherwise all of the circuitry was present.
For commonality, there was little mention of its function, but someone found out by trial and error, that fitting the bulb in the dash permanently allowed the blink codes to display on the dash, instead of messing about hanging upside in the footwell prodding bits of random wire in holes. At least, that's how I understood it. (There was still some prodding, but not so much) I had to read between the lines of americanglish, so some of it might have been lost in translation. To John Clayton, I should say- One point of caution in your original post on this topic, is the 'accessing the diagnostic program.' It's not quite that advanced. If your garage are expecting some wizard output that says 'code/sensor FUBAR', they might be sorely disappointed. What actually comes out is a four character blink code. That is then referenced to a table by the very human part of the diagnostic program, ie. the Technician, or the Technicians Monkey, which will give a very broad reference to a sensor not giving a correct output. It's fun, but archaic. There's some notes about this (MAC05) on Phil Paynes Isham research website. Two notes- Autocorrect has a slightly Freudian aspect to its function, me thinks; FUBAR autocorrects to 'Dubai', and Isham to Islam. Neither of which have any practical value in this discussion, btw.
That's the same relay that I have in my MB quattro which uses the same setup for code reading.
