Classic Audi » Technical » Mech/Tech » Suspension & Brakes » b2 90 quattro strut top mounts
Old 23-07-15, 10:37 PM   #1
willow
Default b2 90 quattro strut top mounts
Are the top mounts the same front and rear on a b2 90 quattro?
also, what is the best option for this part?
OEM, or something else uprated?
Aftermarket any good?
willow is offline   Reply With Quote
Old 23-07-15, 11:41 PM   #2
Theoretically, no. For practical purposes, yes.
Due to living in latvia and in reality, not dream world, I put lemforder top mounts with increased height on both axles. Most of this forum users likely uses either stock dimension parts, or uses them with "savers" [inserts that prevents them from functioning, thereby saving them], or some racing oriented drivers maybe uses solid mounts. Question of taste and intended use of the car.
Old 24-07-15, 04:01 PM   #3
willow
Are the fronts the same as the rear? they appear to be...
Old 24-07-15, 09:56 PM   #4
Like I said. Part numbers in ETKA are different. I haven't seen original ones, obviously rear ones in my A90q had been replaced by some generic front ones, and I did the same, as there are no issues with this.
