Classic Audi » Technical » Mech/Tech » Engine » Idle problem
Old 10-07-15, 07:26 PM   #1
gazza1971
gazza1971's Avatar
Default Idle problem
Took the car out tonight for a run 1993 2.0 16v coupe perfect until the journey home and now it won't idle cuts out every junction or when u change gear but runs perfect when driving ? Any ideas
1993 B4 Coupe 16v
gazza1971 is offline   Reply With Quote
Old 10-07-15, 08:12 PM   #2
audizzz
Wonder how valid this info is but had same problem develop on a journey in my (dare I say it) PROTON.
An earth wire connection had corroded, 30 second fix by my mechanic.
Had to keep the revs up and brake with my right foot on journey home.
audizzz is offline   Reply With Quote
Old 10-07-15, 08:15 PM   #3
audizzz
Make that left foot
Old 10-07-15, 09:29 PM   #4
Ben
Does it try to idle with the revs rising and falling but stalls, or does it just die coming off the throttle?
1992 80 quattro 20vt
Old 10-07-15, 09:32 PM   #5
gazza1971
gazza1971's Avatar
Dies when u come of throttle and was taking around 5 seconds or so to start.
1993 B4 Coupe 16v
Old 10-07-15, 11:01 PM   #6
(Was writing this earlier when the battery died.)
Is idle entirely controlled via ecu/valve? If so, my guess, and it is just a guess, is the idle control. Signal to, connection, or valve itself.
A bad closed throttle switch on one of mine results in similar behaviour to older cars with blocked idle screw. Revs stabilise slowly, dies approaching junctions.
Presumably, so long as your foot is on the throttle, it stays running.
What about when you start it? Does it try to start? Die straight away?
Old 11-07-15, 01:13 AM   #7
gazza1971
gazza1971's Avatar
Exactly as you describe it does can u clean the idle control valve ? Going to get it in to a garage today see were it goes from there. Thanks.
1993 B4 Coupe 16v
Old 11-07-15, 04:41 AM   #8
Ben
The link is not working.
Old 11-07-15, 05:58 AM   #9
Before you mess up your ISV with the so called "cleaning", check all intake elements. No idle and hard start more sounds like small air leak.
Old 11-07-15, 02:12 PM   #10
gazza1971
gazza1971's Avatar
It's booked it to a Audi specialist Wednesday going to start with a smoke test for air leaks. Thanks guys for the input.
1993 B4 Coupe 16v
