Classic Audi » Technical » Mech/Tech » Interior » Water in boot
Old 05-06-15, 11:41 AM   #1
F124nny
Default Water in boot
I just got my 90 b2 on the road and found water in my boot. Does anyone else have or had this problem and is it a common fault
Need to try and sort it as got pram and stuff to go in there
Nathan
F124nny is offline   Reply With Quote
Old 05-06-15, 12:33 PM   #2
Flying Frank
Flying Frank's Avatar
From past experience, the "favourite" place for water ingress is around the rear light clusters. Remedy is to carefully remove light units, clean off old mastic and then re-install using appropriate new black mastic strips....some of the other guys will doubtless describe those strips more professionally.
Old 05-06-15, 12:40 PM   #3
AKD49701004
http://www.vwgenuineparts.co.uk/parts/VW_Seal.shtml
'Sealing cord'. But it's a stiff gum type seal.
Old 05-06-15, 01:52 PM   #4
Flying Frank
AKD49701004
I stand corrected!
Old 05-06-15, 02:30 PM   #5
F124nny
I need a new set of rear lights so may as well see if can find new ones and replace rubber seal on them
Where can I get it shop wise or best ordering offline
Old 05-06-15, 02:58 PM   #6
Flying Frank
Are your rear lights the same style as on the Audi 80 , if so I managed to get lenses for mine from a place in Germany, the bulb holders are a bit harder to find .....?
Old 05-06-15, 03:01 PM   #7
I stand corrected!
Not really corrected. It can be horrible stuff, which gets messy when very warm, Almost mastic like; and stiff and barely pliable when cold and mixed with 2-3 decades of grit. It does the job well, but once disturbed needs to be replaced or at least added to as it's usually well recessed into the grove.
Most body shops can't be bothered, though
Old 05-06-15, 04:12 PM   #8
F124nny
I just need the lens. But will see what can find out there. Need to get on Herman site it's just the postage
Old 05-06-15, 11:39 PM   #9
ian20v
ian20v's Avatar
My s6 has developed a similar ailment tyrewell had a litre or so of water,felt overlay soaking too,needs further investigations
1987 audi 200 Quattro saloon sorned,few bits to do yet.
1987 Audi 200 quattro avant sorned,getting rebuilt
Daily Toyota Hilux 1999 2.4td double cab
VW caddy van 1.9tdi 2010
Old 06-06-15, 02:16 AM   #10
escovedo
Reseal the boot vent.
escovedo is offline   Reply With Quote
