Classic Audi » Technical » Mech/Tech » Transmission » rear diff lock sticking on
Old 10-05-15, 09:53 AM   #1
Gaz
Gaz's Avatar
Exclamation rear diff lock sticking on
The rear diff lock light on my cq will stay on after turning the switch off. And i have to get under the rear of the car and give the actuator a wiggle (if that's the technical term) in order to get the rear lock to disengage and the light to go out.
It seems to move a little bit on its own, but just not enough.
It also looks very oily.. Could it just need a clean? Or new vacuum lines? Or could it be the diff it self that is the problem?
Cheers.
Old 10-05-15, 01:12 PM   #2
yeti
My limited understanding of it is that the lock is applied by the presence of a vacuum, and disengaged by the vac being released, so that would discount a vac leak for me, the lock wouldn't engage.
Im guessing its just gunked up.
2003 Cors-arrrgh
Old 11-05-15, 03:16 AM   #3
Not really. Actuator has two sides, and lock is engaged or disengaged depending on which side has been connected to vacuum system. In this case it sound like the side, which disengages is not receiving any vacuum.
Old 11-05-15, 05:27 AM   #4
Hanuman
Hanuman's Avatar
The rear diff lock arm is also prone to a lot of corrosion due to build up of crud and road grime. They can get caked. Rusty actuator rods that get so thin they snap, and the pin and yoke that link the actuator to the arm, impinging the movement.
Another frequent problem is the actuators themselves, which are suffering perished diaphragms internally, so they are not so flexible, and the plastic body of the actuator getting brittle, so that the hose connections crack, resulting in partial loss of vacuum and eventually total failure. As mentioned, they receive vacuum to either chamber depending on whether being locked or unlocked.
They are easily damaged anyway.
A Mercedes part has been found to be almost an exact match, with some small modification.
I find that both my diff-locks occasionally stick; Either not engaging immediately, but they do engage as soon as the car moves, and likewise disengaging. In the worst case, going into reverse and moving backwards a short distance is enough to disengage. A lot of cars experience that.
Old 12-05-15, 12:20 PM   #5
M4rkp
M4rkp's Avatar
As The Real MSH says - it needs vacuum to engage AND disengage.
You need to check the pipes from the diff lock control to the actuator ( yellow and blue IIRC) with a MityVac - Its more likely to be the actuator itself, probably the sealing ring around the actuator shaft that is leaking. In some cases the retaining screws swell up with rust and crack the casing.
Its easy enough to take off - they are NLA from Audi but there is a Mercedes part that works.
I had the same issues last year - have a look at the link below.
http://www.quattroforum.com/index.ph...ctuator.24641/
Mark
M4rkp is offline   Reply With Quote
Old 25-08-15, 05:05 PM   #6
kat1127
Hi, any more info on the merc part, the link doesn't seem to work t.i.a
kat1127 is offline   Reply With Quote
Old 25-08-15, 05:21 PM   #7
jimh
http://www.quattroforum.com/index.ph...14/#post-82528
You can usually find the Merc part on Ebay.
Old 25-08-15, 06:28 PM   #8
ChrisG
ChrisG's Avatar
I had a similar problem many years ago ( 1991 iirc) and after checking the freeness of movement I checked all the vacuum lines.
Under the bonnet the lines were breaking up ( a fairly rigid plastic) , probably age - although at that time only about five years old, and aided no doubt by heat from the engine.
The rest of the lines were OK.
Replaced with some tough piping and everything was fine !
Old 03-12-15, 07:10 AM   #9
Colin Aitchison
Colin Aitchison's Avatar
Hi Gaz,
The only problem with any of my diff locks was that they came on by there self when the engine was revved on load over 3000rpm, there is a one way black and white valve on the vacuum pipe work behind the diff lock knob in the center consul, when this one way valve lets the vacuum pass both ways it draws the diff lock on, this was on a 1984 WR UR quattro.
