Members: 43,081 | Total Threads: 40,087 | Total Posts: 471,054 Currently Active Users: 15457 (3 members and 15454 guests) Welcome to our newest member, Scottmat |
a couple of days ago the drivers door lock stopped working when i press the alarm button on the key phob.
![]() any idea whats most likely gone wrong? I suppose i need to take a look, but can't be arsed in this weather. I just hope it simply needs a new motor maybe? I just hope it isn't the alarm it self that has c@cked up. ![]() Anyone else had this problem? I guessing all this cold weather has done something to it. |
I presume this is the pneumatic type locking system?
Youll likely have either an obstruction of some kind preventing the actuator from locking the door or an air leak to that actuator so it dosent get full vacuum pressure. Could be something as silly as a pipe off or split, or possibly trapped. |
Black Coupe Collector
Could even be its iced up perhaps?
95 UrS6 87 Coupe Quattro |
The coupes never had remote locking so it will be an aftermarket fitment could be as simple as the rod has come of connecting the actuator to the door locking mech. only way to know is to take the trim off and have a look . I take it the cetral locking works if you use the key ?
if its the key fob it could be the battery in it ,does it lock with the key ?
#6 | |||
it never has since i bought the car. I'm guessing someone has replaced the mechanism that opens the door, but forgot to swap the key barrels over. ![]() Quote:
however, i'm 90 % sure that the drivers side on these cars uses an electric motor. as you can usually hear it swiftly lock and unlock. (or you could before it broke) So now its just silent, and does nothing. ![]() *- On my GT however, its broken in a different way. the vacuum works on the passenger door, but you can here the motor in the drivers side spinning away to its self but not being able to lock the door. ![]() |
that's normal for the passenger door.
The central locking only enables from the driver's door
| key don't work in drivers door?? | Gaz | Bodywork, glass & exterior fitments | 2 | 07-12-09 04:02 PM |
| Broken door lock | Ringmaster | General Chat | 8 | 30-09-08 08:04 AM |
| Drivers door bump strip | a25c | Parts Wanted | 2 | 28-09-08 11:58 PM |
| Drivers side door trim '82 GT5 | snorky | Parts Wanted | 11 | 26-09-08 11:01 AM |
| type 85 80/90 door lock barrel/s and key | spink | Parts Wanted | 5 | 31-07-08 06:11 PM |
