Classic Audi » Classifieds section » Parts For Sale » please look
Old 18-03-15, 06:06 PM   #1
sam
Default please look
b3 80/90 bonnet in very straight condition, 1 tiny little dint i found but that would be rectified when its getting painted the required colour, small amount of surface rust on the underside of the bonnet
£50
b3 80/90 saloon ski bag
will include tank (fwd only i think, as the tank outlets are on opposite sides) carpet etc
£50 need this gone
audi 90 20v sport master cylinder
£40
audi 90 20v sport gearbox
includes linkage
£75
7a distributor with brass gear
£50
audi 90 20v sport abs pump, will fit other
£30
7a water outlet with mfts
£30
audi 90 power steering reservoir. as with a lot of these parts its minging and needs cleaned but no leaks
£15
audi 7a airbox inlet pipe, split but better than 1 you havn't got i suppose
£10
audi 5 cylinder water outlet
£10
powersteering pump to cooler pipe, pipe 7a/s2 etc
£15
rad support bracket
£5
7a injectors, fuel rail and fpr
£40
7a dizzy cap and plug leads
black outer casing damaged but doesnt effect use
£20
7a metal block breather pipe
£25
power steering cooler pipe
£30
nissens rad includes fan/shroud etc
£45
s2/80/90/coupe quattro rear koni adjustables
spares or repairs
£50
Old 18-03-15, 06:36 PM   #2
leggy
I'm after two oval black/chrome 'Audi' front wing emblems/badges and an 'Audi' chrome boot emblem if you have them please?
Old 18-03-15, 06:46 PM   #3
leggy
Default additions to above
These too if you have them please? -
Boot wiring grommet (893862113)
Ashtray drawer insert tray (893857961)
Cigarette lighter: the part that you use to light your smokes!
Accelerator stem/pedal (832721507C)
Lambda Sensor (034906265F)
Battery terminal nut & bolt x2 (nut:N01100636/bolt:N0174052)
*known part numbers in brackets
Old 18-03-15, 07:28 PM   #4
sam
pm on route
Old 18-03-15, 09:16 PM   #5
joe90
Where about's are you sam
Bryan
Old 18-03-15, 09:32 PM   #6
sam
newcastle mate but i am heading to bristol on sunday if anyone is on route and needs anything..
Old 19-03-15, 07:34 PM   #7
quattrostyle
Any more interior pics?
Old 19-03-15, 07:58 PM   #8
sam
thats all i have at the minute.. also have a 90 sport interior cheers
Old 20-03-15, 08:42 PM   #9
leggy
Originally Posted by sam View Post
This interior is soooo my car, and your gear stick fabric covering is in much better condition than mine too, so could I add it to my list please?
Did you get my latest PM?
Old 20-03-15, 08:58 PM   #10
Audimike67
Hi ,
Wondering if you've got the steering column switches , headlights etc.
cheers. Mike
Audimike67 is offline   Reply With Quote
