Members: 19,777 | Total Threads: 40,090 | Total Posts: 471,079 Currently Active Users: 2136 (5 members and 2131 guests) Welcome to our newest member, EdwardHargy |
DSY 01E 6 speed manual gearbox 4.1 final drive as fitted to 1999 s4 these boxs have connections to run a oil cooler if req, box in good condtion sorry no mounts or gear linkage £350 . coupe quattro rear diff complete with mounting arms 4.1 final drive £100. rare [i think] 80 quattro rear diff complete 4.6 final drive as fitted to the 1.8 gti engined 80quattros £100 . 20v timing cog gen [ the small one that bolts to lower front pulley]new part with gen audi bolts £25 . all prices plus postage ray
Hi Ray
You don't have a rear subframe for a 1995 coupe Quattro as well do you? Regards Andy Sent from my iPhone using Tapatalk |
no sorry i dont have a spare subframe
Ok thanks for replying, if you do bump into someone who has one could you point them my way!
Kind Regards Andy Sent from my iPhone using Tapatalk |
i beleave you can use a subframe off a earlier car [coupe quattro /ur] if req , you may just need to cut off your brackets for anti rollbar to refit tem to new subframe
ALL the above parts still forsale . apart from lower front pulley cog sold
#7 | |
http://www.ebay.co.uk/itm/AUDI-90-CO...item417c424e97
1997 Audi S6 Ruby Red |
Hi geneandbolly
Thank you very much for the pointer but I have just now sourced one! Kind Regards Andy Sent from my iPhone using Tapatalk |
sill forsale, coupe quattro complete rear diff 4.1 final drive with mounting arms £100. rare 4.6 rear quattro diff ,beleave it was fitted to the early 1.8 audi 80 q complete this unit has the mounting arms cast with the housing like some ur diffs £100. complete set of S2 ABY coils with cam cover and coil pack cover £100 or £50 for just the coils, 01e bearbox from 1992 s4 , needs strip down as gear changeing was stiff £100 . pls pm . thanks ray
