Classic Audi » Classifieds section » Parts Wanted » S2 running gear wanted
Old 30-01-14, 12:08 PM   #1
jogi730
jogi
jogi730's Avatar
Default S2 running gear wanted
Hi all,
High time to finally convert the 90 to S2 running gear.
Has anyone got full set for sale (hubs, uprights, subframes, driveshafts, ARB's).
It may be more cost effective to buy a rolling shell.
Can anyone help please?
jogi730 is offline   Reply With Quote
Old 30-01-14, 03:40 PM   #2
martinws
I've got uprights and a stock RARB I'll have a look to see what else.
Old 30-01-14, 04:11 PM   #3
jogi730
jogi
jogi730's Avatar
ok thanks
Old 30-01-14, 09:59 PM   #4
20vcqdriver
20vcqdriver's Avatar
What's the main reason for this Chris. If its just for the 5 stud hubs. I'd just change these. If changing struts best check spring plate height etc....
Old 30-01-14, 11:23 PM   #5
jogi730
jogi
jogi730's Avatar
I want to improve ride on car. My setup is far too stiff and makes the car a bit skitty. The 5 stud setup is far beefier and there are loads more options
Old 30-01-14, 11:44 PM   #6
Hamish
Its the way to go Chris opens up a lot more suspension options.
Hamish is offline   Reply With Quote
Old 31-01-14, 09:24 AM   #7
20vcqdriver
Have to say after 15 years of experimenting I now find my present setup of H&R 30% uprated and lowered springs, Koni adjustables turned one full turn to firm and rear ARB perfect , not too harsh but good balanced handling with little roll when pushing on. Certainly no worse than a modern day S-line or LeMans and not too low it looks silly
Old 31-01-14, 09:37 AM   #8
Hoyle
80q addict
Hoyle's Avatar
There are better options for coilovers, better camber adjustment, and the struts are lighter IIRC.
Hoyle
My 80 Quattro thread
Old 31-01-14, 10:02 AM   #9
20vcqdriver
Hoyle
Will lighter make much difference on a car with 500+ bhp???
Old 31-01-14, 10:13 AM   #10
Hoyle
80q addict
Hoyle's Avatar
Unsprung weight will make a difference to the suspension, handling and braking/acceleration characteristics, besides the kerb weight.
For instance, the suspension will respond quicker, and therefore road contact in increased. Although this may not be noticebale in some cases.
This is the reasoning for lighter calipers, lighter wheels and often 2 piece discs (besides the heat dissipation).
