Members: 43,049 | Total Threads: 40,085 | Total Posts: 471,036 Currently Active Users: 2694 (1 members and 2693 guests) Welcome to our newest member, Josephnep |
#71 |
Can't remember if it was you.. but someone was showing and earth strap from the coil area and didn't know where it was supposed to go. I have one that goes to one of the bolts on the cam cover. Maybe wasn't you who knows.
Wouldn't make much odds anyway in terms of the starter probably.Charged battery - check Battery earth - check Engine earth straps? Is it really hard to get the starter out? How long has it been sitting? A little van I had you could squirt some WD into a tiny hole in the starter solenoid and smack it with a hammer while someone held the key in starter position. Dash lights going off when in cranking position indicates a voltage demand at the starter does it not? Like the starter is seized? You'll get it soon! Use the force. |
#72 | |
#73 |
check-
Relay box. All the relays in position. It may even pay dividends to remove and reseat each one. Starter link. The large copper bus link in the location where the auto box/park relay sits. Can't member it's location. When the ignition is turned on to first position, the solenoid on the bulkhead, to the passenger side of the hydraulic reservoir should click. there should be 12v here. Immobiliser. It may be worth disconnecting the battery, waiting a mo, and reconnecting, if you haven't already done that. Then disarm it again. I hate the bloody things. Many have small relay circuits which after some years use, and more disuse, simply refuse to pass current.
#74 | |
The distributor was refitted 180' to where it normally was, but, as I was building to an old photo I put the cap on the way it used to be... i.e. 180' out! Turned the bugger around and it starts cranking and if I'd kept it up would have eventually fired, however when I stopped turning it over I could hear fluids leak.... Turns out I've got fuel leaking from these two lines here: ![]() ![]() I've done the bolts on both of these up as tight as I'd dare but there's still a very small leak and sounds like a radiator when you open the bleed valve by the tiniest amount. I just reused the bolts that were in it originally, should there be washers or 'o' rings around these too? How should I go about stopping the leak
#75 |
“Been raced and rallied”
The two banjo's should have a washer top and bottom brass or alloy I find that the alloy ones are the better fit as brass isn't soft enough any more..
#76 |
Should have new crush washers fitted
#77 |
#78 |
#79 |
Perfecto. Anyone off the top of their heads know what sizes? I know one bolts got a 14mm head and the other a 13mm
#80 |
8 x 11.5,(x 1 mm). 2 off
10 x 13.5, (x 1mm) 2 off ..
