Classic Audi » Technical » Mech/Tech » Engine » KG Engine
Old 12-09-13, 07:52 AM   #1
john bowden
Default KG Engine
Just a quick one,
If I wanted to replace the WR engine in my UR quattro with a KG unit from a 200, and use all the parts from my car ie turbo exhaust, inlet etc, what issues would I come up against?
Thanks
John
john bowden is offline   Reply With Quote
Old 12-09-13, 09:31 AM   #2
The KG head has a feed to take inlet manifold air into a gallery behind the injectors. I'm using a KG head on my WR. This is capped off. I think it is normally fed from the middle of the inlet manifold.
On the block, I believe there is a more extensive breather system. Otherwise, top end, most of it is a straight transfer. I think you may be better off using the original WR inlet manifold.
If your WR exhaust manifold is viable, it's worth using it, too.
I don't know about compression ratio, but somewhere in my head, there is something about piston crowns being different. This is not a major issue though, as the engine will work.
TimC's rally monster is KG based.
Old 12-09-13, 10:35 AM   #3
john bowden
Thanks for the advice.
I'll be using all the manifolds turbo and other ancillaries from my WR, so it looks like a go-er
Searched on some other threads on here and quattroforum, and sump may need to be swapped, but thats not really an issue either.
Thanks
John
