Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2660 (0 members and 2660 guests) Welcome to our newest member, BuddyInons |
#11 |
Switch without a doubt. Way more sophisticated KE-jetronics made use of pair of switches, so no doubt for this primitive setup. In any case it's not that hard to touch around throttle to look for connectors, since any connectors would be attached to throttle body anyway.
#12 | |
#13 |
Whats missing here?? Bracket to the left of the dipstick has had something fitted to it....but not now?
![]() I remember reading somewhere about "cooling pipes to injectors"?....or am I perhaps getting confused with the turbo'd 10 valve engines ![]() Also what would cause the engine to cut out whilst sitting in traffic? .... After cutting out it would turn over and fire but barely reach idle speed before dying again......could hear the fuel pump prime when turning ign to on but the way it fired then imediately cut again was really like insufficient fuel pressure. I then left the car to cool down for a few hours, then started no problem and drove 30 miles home. ![]() John. |
#14 | |
That bracket is for the injectors cooling motor. Not critical in this country most of the time and series 2's never had one.
#15 | |
The injector cooling motor will explain the 2-pin plug doing nothing down there as well. |
