Members: 43,031 | Total Threads: 40,083 | Total Posts: 471,017 Currently Active Users: 3312 (1 members and 3311 guests) Welcome to our newest member, Clamcasexgd |
#31 |
all parts cheap to clear,as i need the space for the next lot of parts thats coming!!
#32 |
i have abbandoned my project so all is for sale
i have half a garage full of parts to clear i will add and remove from the lists as i find things as there is a lot..... would prefere collection on the larger items if poss If the price is not ok,pm me with an offer parts are from.... s6(1996 aan) type 85 coupe quattro type 85 80/90 s2 TYPE 85 audi 80/90 screen £60 front indicators £10 offside fog lamp£20 bonnet mint in silver £25 80/90 inlet hose trunk(Michelin man)£20 COUPE QUATTRO rear screen with quattro enscript £40 rear 1/4 glass with quattro enscpit£15 each rear subframe £85 front subframe£45 rear bumper in black £20 all 4 door panels £30 door glass £15 each dash £20 clocks£10 clock surround and switches£20 boot spoiler painted type £25 full wiring loom £40 rhd wiper mech/motor £15 clutch master cylnder£15 3 x headlamps only good for parts £30 2 x sloping type grills £25each alternator £15 fuse box with relays £20 n/s/r strut/hub £20 S6 AAN inlet manifold £100 rocker cover £30 5xcoils(no cover)£80 2x pos £50 altitude sensor £25 s6 diff £20 starter motor £20 engine loom complete £150 flywheel and clutch£40 aan pas pump looks to be new or recon £60 after run pump £25 wastegate needs rebuild £25 lambda sensor £15 throttle body to isv hose£20 complete gear linkage £125 water rail £50 dash switches £10 n75 x2 £10 isv valve £15 fuel pressure reg £15 s6 front badge mint £15 2 x gear knob 6 speed no rips £15 S2 aby dmf and clutch £40 inlet hose(throttle body to isv)£15 |
#33 |
Rob.... doing a coupe resto at the moment and could use a driver's door window (green tint), to replace a scratched one. Also could be interested in the 'clocks' as long as it doesn't have starship mileage on it. The one fitted to the car has been tampered with, but the previous owner claims it had around 120,000 miles on it when he sold it. So anything around this would be ok.
#34 |
i will take any reasonable offer on the above parts,space needed and i dont really want to scrap them
#35 |
1 6-speed knob for me then please, needs to be posted to NL
#36 |
V8 Powa!
Hi, can you drop the picture of Flywheel please? is it 8 bolt or 10. TA
--- Buy Quattro - They said Be FUN - They said |
#37 |
#38 |
V8 Powa!
em ... will need to fit *077 clutch (spring) on that..
240mm. 8 bolt. (havent checked the center) Need single mass flywheel due to spring clutch.
#39 |
Only 8 bolts on these here
This lot will be getting scraped at the end of the month |
#40 |
Friday night bump
