Members: 43,039 | Total Threads: 40,083 | Total Posts: 471,018 Currently Active Users: 638 (0 members and 638 guests) Welcome to our newest member, Danielordem |
Worked fine when I parked it up over winter (it's been a long, cold winter round mine). Went to start it the other day and it didn't work.
Here's what I've got: 1989 2.3 NG, so K-Jet injection, or some derivative thereof. A patchy amount of K-Jet knowledge from previous 924 and XR3i ownership Fuel pump primes. Fuel comes out of the feed to the fuel disi if I take it off. Therefore I surmise a) It's not out of petrol b) The fuel's getting this far at least Plugs are new and sparking well, but dry Car cranks (now it's met Mister Boost Pack) Car momentarily fires when cold but stalls immediately Taking the injector lines off the fuel disi the lines are all dry, except the cold start, which chucks out anice big glug when primed. Lifted the airflow meter boot and the flap in there's moving freely. Lifted the fuel disi and the plunger isn't seized, but there's some resistance there to it's movement. Annoyingly, my mutimeter's at the workshop, so I can only test for power to the fuel disi with a bulb, and don't particularly want to chance this if it's gonna cause a problem elsewhere. Any other tests you can suggest good people?
Air leak somewhere. Maybe fuel injection ECU not providing starting current to pressure regulator.
Thanks for the quick response dude!
Found my meter! Where do I check the pressure regulator?
Does it have a Warm up regulator?.....its normaly side of the engine block
I had this on my 1990 coupe years back it puzzled even the main dealer , I had a new ECU and it resolved it , after I left it with a main dealer for 7 weeks !
#6 | |
ECU? Didn't know it had one?
sorry, ive showed you a Warm up reg of a 1781 DZ.....yours being NG will be differant/system
It has two. Since fuel pump is turned on and you've got spark, I guess ignition ECU is not of your interest. To check fuel injection ECU function, you have to measure current in series with pressure regulator with ignition turned on but engine not started, should be between 90 and 120 mA.
Stale petrol?
Ignore that. ![]() Just re-read Plugs are new and sparking well, but dry
