Classic Audi » Technical » Mech/Tech » Transmission » Clutch slave cylinder procedure/where to buy?
Old 06-11-11, 03:50 PM   #1
Jolfa
Default Clutch slave cylinder procedure/where to buy?
I thought I could get away with using the existing slave cylinder on my KV quattro box, and it wasn't too bad, but now the bleed nipple has snapped off in it, and I still can't get 1st or 2nd.
So, can this be done with the box in situ or is it just not worth wasting time and just get it straight out? Literally a case of pulling the pin out and beasting it out, no bolts or anything?
Where's the cheapest place to get a new one from?
It's a 1986 90q using the original KV gearbox if it makes a difference
Ta
Edit - 1986, not 89!
Jolfa is offline   Reply With Quote
Old 06-11-11, 04:19 PM   #2
Phil Payne
http://www.isham-research.co.uk/quat...-cylinder.html
Much the same.
Old 06-11-11, 04:34 PM   #3
Jolfa
Cheers, any recommendations for a place to get a newun for sensible money?
Old 06-11-11, 04:51 PM   #4
Phil Payne
GSF. Very common part used all over the place.
Old 06-11-11, 04:53 PM   #5
TeXerv
TeXerv's Avatar
[quote=Jolfa;243649]Cheers, any recommendations for a place to get a newun for sensible money?[/QUOTE
Hi,
what is sensible? 35 GBP? I don't know about cheap price in GB
Old 06-11-11, 05:07 PM   #6
Jolfa
Sub £40 would be sensible, sub £25 would be great
Old 06-11-11, 05:14 PM   #7
TeXerv
TeXerv's Avatar
35 is possible from Germany (add shipping). A repair kit would be pretty cheaper but if the bleeder is ripped, this will make no sense.
Old 10-12-11, 06:47 PM   #8
dunstan
Will it not bleed by cracking off the banjo. Sometimes works.
dunstan is offline   Reply With Quote
