Classic Audi » Classifieds section » Parts Wanted » wanted lowering springs b2 80 quattro!
Old 24-10-11, 09:36 PM   #1
jimski2001
Default wanted lowering springs b2 80 quattro!
Anybody got any lowering springs for a 83 80 quattro b2
anything considered
not sure if any other models use the same, so any info on this would be a bonus.
also any advice if others have changed them before on the same model
cheers guys
jimski2001 is offline   Reply With Quote
Old 24-10-11, 10:21 PM   #2
A_N_Other
I've a pair of front -60mm (I think) springs in a fetching shade of red....
I've used the rears are at the front on my motor (they are actually a higher spring rate, which is what I need)
I think fronts are 125lb/in, rears 150lb/in
At the back I'm using some V6 coupe springs (and same dampers all around) as they seem to be about the same rate and length - V6 coupe dampers are shorter than standard too and seem to be on the money (and cheap as standard gas shocks at GSF etc...)
A_N_Other is offline   Reply With Quote
Old 25-10-11, 07:52 AM   #3
doninphi
doninphi's Avatar
How do these differ to fwd springs?
I'll have a pair of fwd -70mm spare soon...
I'm trying to free up the rears but need some mk2 golf coilovers first, but then I guess they are different too being fwd??
I make vinyl STICKERS! Pm me for any design you want...
doninphi is offline   Reply With Quote
