Classic Audi » Classifieds section » Parts Wanted » Wanted! Coupe GT 1987 rear axle.
Old 23-04-11, 08:13 AM   #1
SorenR
SorenR's Avatar
Default Wanted! Coupe GT 1987 rear axle.
So far all attempts to locate a rear axle in Denmark have failed, so the search is widened.
The car is a 1987 Audi Coupe GT 2.2L 10V KV (136 hp) with discbrakes rear.
If you have a spare, know of one or have knowledge of an alternative to the original axle, please contact coupe-gt or myself SorenR. My phonenumber is +45 2999 5670.
We need to get this beauty back on the road as it is greatly missed by the owner!
This is the state of the current rear axle..
SorenR is offline   Reply With Quote
Old 17-05-11, 04:04 PM   #2
davow
davow's Avatar
Default ebay de
just seen this on ebay de off an earlier coupe with drums, dont know if you could use it or not ??? I know bryflyingby has converted his to hold disks from a mk2 golf
http://cgi.ebay.de/Hinterachse-Tromm...item563cea6f6a
davow is offline   Reply With Quote
Old 17-05-11, 08:48 PM   #3
mrtat2k8
dont know if its diffrent but i have one from a b3 type if i could see some more pics and leanth on the rear axle i would be able to look to see if its the same thanks
rob
mrtat2k8 is offline   Reply With Quote
Old 17-05-11, 09:50 PM   #4
yeti
Normally on VAGs you just swap the stub axle to go between rear drums and rear discs. The bolt pattern seems to be to any old FWD VAG I've ever dealt with, but I can't guaratee that.
I've got a spare, drummed, rear beam, but I don't know how we'd go about getting it to you?
2003 Cors-arrrgh
Old 21-05-11, 10:55 PM   #5
SorenR
SorenR's Avatar
Status update...
Aparently axles with drums and axles with discs are not the same.
Anyways, Audi found a new rear axle, so the car should be on the road again very soon.
Thanks to everyone for your interest in our quest.
Old 22-05-11, 08:53 AM   #6
quattrostyle
wow you ordered a new one?
Old 22-05-11, 09:27 AM   #7
SorenR
SorenR's Avatar
Default Re: Wanted! Coupe GT 1987 rear axle.
Not my car, the car belongs to a good friend... It was the only viable alternative. All the rear axles available were rusty and required some work before fitting and with the rest of the car in mind, a new rear axle seemed the most sensible thing to do.
