Classic Audi » Community » General Chat » 20th anniversary
Old 22-03-11, 08:54 PM   #11
20vcqdriver
20vcqdriver's Avatar
About time you modified it then...?...
Just got the final bits for the water/methanol injection Should be able to keep up with your short ratioed monster now
TSR engine was a 2337cc, pack C big valve head and mild 268cam. Kicked out a healthy 175bhp, But dropping a valve was the one of only 2 times the car has left me stranded, Tim sorted me a non hydraulic head to replace it but I already had other plans by then.......
Old 22-03-11, 09:06 PM   #12
I'm sure you know this already, but my brothers big valve TSR head dropped a valve after about 20k miles too. The Collete wore through the valve stem and allowed the valve to pass through into the chamber.. His dropped at about 2500rpm on a trailing throttle running up to a roundabout... Didn't help, engine was still toast....
PS, 20vT is the way to goooo.....
Old 22-03-11, 11:04 PM   #13
20vcqdriver
That is either a coincidence or a serious design fault/ cheap collets used by TSR as mine was an identical failure although mine failed just as I pulled onto a dual carriageway, scary for me and several others..
Old 23-03-11, 09:10 PM   #14
DJones
DJones's Avatar
My UR has been with me for 17 years, last November.......
Time flies.......
Darren.
DJones is offline   Reply With Quote
Old 23-03-11, 09:19 PM   #15
20vcqdriver
Time flies.......
Darren.
And I would be keeping it too if it was as much fun as yours with 400+ bhp
