Classic Audi » Technical » Mech/Tech » Engine » hunting idle when cold
Old 27-02-11, 11:05 AM   #81
Gouldy
Gouldy's Avatar
i know the switch clicks when the throttle is moved, however havent had a look at the readings,
Old 27-02-11, 11:13 AM   #82
Phil Payne
Originally Posted by fj1200 View Post
Forgot to mention, make sure the micro switch on the throttle valve is working properly. Unplug the connector, usually 3 pins and jumper the obvious pins leading to the idle switch, see if the idle simmers down.
Stone me! A newbie talking perfect sense!
Yes, you're right. We don't set by duty cycle this side of the pond because Audi (in their infinite wisdom - let them be praised) deleted the test connector from the engine bay.
Substituting for the gas analyser, we often use the Colortune. It's a spark plug replacement with a quartz window that lets you observe combustion. Roughly speaking, four 'blue' flashes to one 'yellow' equals about 1.25%. Our MoT limit on older cars is 3.5% - so it's pretty easy to set up a pass level.
Old 27-02-11, 11:19 AM   #83
Takes a bit of pressure off you,to come up with the answers all the time.
More brains,for everyone else to pick.
KARL.
Old 27-02-11, 01:23 PM   #84
fj1200
Setting for a pass level is one thing, setting CO so the car runs properly is another. At 3.5% the car will run pig rich and probably load the plugs at an idle. Does this car have an O2 sensor? Phil mentioned the test connector was deleted, if there is in fact an O2 sensor and frequency valve then no test connector is needed. Simply backpin at the frequency valve and read the duty cycle directly. Make sure to do this with the exhaust good and hot after a drive to make sure the O2 sensor is up to temp and swinging properly. Aldo if there is O2 control there should be a white 2 pin temp sensor on the bottom of the upper coolant neck. This will report to the jetronic control unit when to allow O2 control. Make sure this sensor is working properly. I can dig out the book of Bentley later this afternoon and verify pinout and functionality. I need to get the house picked up and go to our annual free whisky tasting
Cheers
Dan
fj1200 is offline   Reply With Quote
Old 27-02-11, 02:07 PM   #85
Gouldy
Gouldy's Avatar
i am sure its the sensor on the bottom of the stat housing after testing the resistance
Old 27-02-11, 02:33 PM   #86
Default This,may help?
I had a similar problem and I renewed the sensor.
Main problem gone,but I now have a bumpy idle.Think the engine must have been set up,with dud sensor??Checks,to be done.
http://www.classic-audi.co.uk/forum/...ad.php?t=16214
KARL.
Old 27-02-11, 07:16 PM   #87
Phil Payne
It depends exactly what you use to measure - the line from the ECU is resistive and documented at 10 Ohms, so it distorts the waveform. You have to go to the ECU (pin 8 on most implementations) which is what the test connector actually does for you.
Orin Eman (on the original US-based quattro list) developed a little PCB that showed the duty cycle digitally - I have one of his PCBs on my MAC12 breakout box.
Old 03-03-11, 11:41 PM   #88
fj1200
Hey man,
How we making out here, did you get a new sensor? Is it time drink beer and put our feet up yet?
Cheers,
Dan
Old 04-03-11, 01:47 PM   #89
Gouldy
Gouldy's Avatar
been too busy this week sadly, and i havent been with the car due to working away, will be ordering one up this week with any luck
