Classic Audi » Technical » Mech/Tech » Engine » KV engine-what does this sensor control??
Old 17-02-11, 06:32 PM   #11
Thanks,for all you replies.
Next day off,I'll have a play around and let you know what I find?
KARL.
Old 17-02-11, 06:55 PM   #12
Sandro
Sandro's Avatar
Only part connected to KV engine that could be called "ECU" is that small control unit, which controls ISV. Probably that sender is for it. For temp gauge and light should be the one which is on top - looks very familiar, the same as on B3 I4 engines.
You are right! Somehow through years all units what controls something on engine - everybody calls "ecu"...
Old 17-02-11, 07:05 PM   #13
ovalking
The arrangement on the KU engine looks exactly the same - wire is the same colour.
Having had a quick look in my Haynes and Bentley manuals, I'm none the wiser.
Injection and ignition systems use the MFTS (above it).
Temp gauge sender is on rear of cylinder head.
Thermotime switch for CSV is in radiator.
This single connection doesn't seem to get a mention.
It could be for the ICU (as previously stated, there is no ECU)
ovalking is offline   Reply With Quote
Old 17-02-11, 07:11 PM   #14
It's got me,scratching my head.
I'll have to,do some research.
I was wondering,if it could have anything to do with my high idle?(Shooting,in the dark.)
KARL.
Old 17-02-11, 07:35 PM   #15
Temp gauage as per 20vcqdrivers post.
The clue being its earthed thru the block.
Old 17-02-11, 07:37 PM   #16
Eddy
Eddy's Avatar
Its something to do with the ISV valve,
If I unplug it with the engine running the idle drops, but if i plug it back in nothing happens untill the ignition is turned off then on again.
Top sender is for the temp gauge.
Old 17-02-11, 07:58 PM   #17
Default What does it control?
Went out and checked mine.
Take lead off and engine doesn't start.
Pushed it back on and engine wouldn,t idle.
Played around alittle more and idle high.(1100.)
KARL.
Old 17-02-11, 08:08 PM   #18
20vcqdriver
20vcqdriver's Avatar
OK. Looked again with my glasses on and it's actually sensor N10. connected to the idle stabilisation unit J142 pin 13/T. used to determine isv operation during cold starting/warm up phase.
Hope this helps
Old 17-02-11, 08:18 PM   #19
Hope this helps
Thanks alot,for that.
So,I might be barking up the right tree?Check some more and check sensor.(Might have to renew?)
KARL.
Old 17-02-11, 08:56 PM   #20
20vcqdriver
Clearing that corrosion off would certainly help
