Members: 19,823 | Total Threads: 40,098 | Total Posts: 471,139 Currently Active Users: 10085 (1 members and 10084 guests) Welcome to our newest member, BuddyInons |
#11 |
thanks very much, got it firing on saturday but the immobiliser wasn't removed from the ecu so it just cut out after a second. so as soon as thats removed im quite confident its going to run perfectly
#12 |
its aliveeeeeeeeeeeeeeeeeeeeee. just got to sort oil presure switch/gauge wires, make coolant flange and pipework from head to heater matrix and a breather setup, yipee
#13 |
got an issue with my starter now. is there a relay between the ignition switch and the starter? just turning the key makes a click but no power to the signal wire for the starter. but 12volts to the solenoid has it fired straight up. theres 2 wires go to the starter, well 3 but 1 is the battery feed so why's there 2 small wires?
anyway relay? ignition switch at fault? sounds fuking great reving up though ![]() |
#14 |
no power to either of the smalle 2 wires. does at least 1 of them come straight from the ignition switch?
