Classic Audi » Technical » Car detailing & polishing » Does this look waxed?
Old 15-03-08, 09:12 PM   #11
heheheheheh there was no red marks on the cloth with the red one and yes you could see that she was waxed as as for the pearl i struggled to see the difference
Old 15-03-08, 11:32 PM   #12
If you're just applying wax then you won't get red on the cloth as wax has no abrasives in it.
All polish has some amount of abrasives though and as early red Audi paint is a single stage paint with no clearcoat, you'll get red on yer cloth.
To be fair, it's highly unlikely that you will notice the difference when applying a wax on to a car unless she's been fully polished first.
The wax is an LSP. (a last step product). You only see the difference when the paint is polished. The wax is just enhancing the appearance and acting as a protectant.
Old 11-04-08, 01:19 PM   #13
Octanejunkie
Octanejunkie's Avatar
Agreed. If the paint/laquer is crap then use a mild cutting polish like G3 or one of its finer derivaties to restore the finish. Then plenty of good quality wax (not yer pound shop shite or squirty stuff). You'll have a sore hand/shoulder as a good wax takes plenty of elbow grease to apply properly, but will keep the cars appearance great.
Old 11-04-08, 05:21 PM   #14
if it's just wax your apply then just apply it gently as wax has no cutting properties and doesn't need to be worked in. Just spread a nice even thin layer either by hand, sponge or foam applicator,in straight lines, leave for about 5-10 minutes then buff off and allow the wax to cure (curing time for a good quality carnauba wax can be anything up to 12 hours)
Old 16-08-08, 11:00 AM   #15
MikeNZ
People say Tornado paint never stays shiny and is hard to take care of it.
I've never had a problem; the key is to get it really shiny initially with polish, then keep a good coat of high quality wax on top.
Old 16-08-08, 12:23 PM   #16
this it aqua waxed plus a dam good waxing with auto glym high resin polish stuff
not bad eh?
Old 16-08-08, 12:37 PM   #17
gabriel.oconnell
gabriel.oconnell's Avatar
hi all as you my know i have a lancia delta intergrale in red a audi quattro ur in graphic grey and a audi coupe in gren blue mettilic, i always use auto glym and will carry on useing it ,like the quattrokid ,s super car his audi its clear to see if you use a good polish it will protect a car well against bird shit which i have seen the result of seagull shit on a mk 3 golf of my next door neighboyur wher it has eaten though the paintwork like acid, in betwwen these waxing your should uses only cold water to clean your car then shammmy the car dry , but polish will also protect the car against salt on the roads in winter, BUT ANYWAY ITS GREAT AMAAMNDA TO SEE YOUR PEARL BACK TO WHERE IT SHOULD BE, SO NOW LOOK AFTER THEM AND ALSO DO NOT FORGET THE RED ONE ITS TOO NICE TO LOOK SAD , HURRY UP AND GET IT SORTED, PS DO NOT FORGET THE BITS FOR ME AT THE RALLYDAY OK
Foamed,2nd waxed and done in!! SteveCat General Chat 7 10-05-08 08:03 PM
